We have a Kenmore Elite Evenheat gas dryer mod. 110.73932102 that won't run when you push the start button in. If you manually hold the button in it will run however it doesn't get hot. Any suggestions?
I'm new to the site and posted this question before I have a chance to check the archives. Thanks for any help, Dave |
Hi Dave,
First swap the heater & motor relay. First unplug your dryer, then swap the motor and heater relay's#37 and #42 here: http://c.searspartsdirect.com/lis_pn...1147-00001.png they are the identical same part. Then plug your dryer in and start it, if it runs and stays running after you release the push-to-start button, then you found the problem, you would need to order a new motor relay. Manufacturer part number 3405281 is RepairClinic item number 528722 ![]() Here's how you get access to your inside console, then the console will lift up and tilt it back on its plastic hinges, remember unplug your dryer first: ![]() If swapping the motor/heat relay's didn't work, then its your control board thats bad. Here's the control board for your model you can order: Manufacturer part number W10116565 is RepairClinic item number 1378522 W10116565Here's our major thread that goes into great detail about it: [FIXED] Another Kenmore Dryer problem Jake
| Kenmore Elite HE3t softener | bibi | Sears Kenmore | 5 | March 22nd, 2009 12:26 PM |
| Kenmore Elite HE3 gas dryer (110.92822100) will not run | bsmitmar | Sears Kenmore | 3 | February 22nd, 2008 12:30 PM |
| kenmore elite front load washer won't run | jen9452 | Sears Kenmore | 17 | September 9th, 2007 08:40 AM |
| Kenmore Elite Drier Model # 110.60056990 won't run | SteveM | Sears Kenmore | 13 | September 2nd, 2007 07:15 AM |
| Kenmore Elite HE3 gas dryer (110.92822103) will not run | AdamRoot | Sears Kenmore | 1 | August 25th, 2005 08:02 PM |
