Old June 8th, 2009, 06:51 PM
Al Huurman is on a distinguished road
Default Beeping Kenmore Dryer
My Kenmore 970-C85072-00 has its own personality.
It would beep-beep at odd times, running or not running.
Sometimes every 1 minute, sometimes every 5. Other than that it was working fine.
Last week it died - still beeps when you push buttons but will not start.
Have tested the following
Have 120V on each line, 240V total.
Jumpered thermistor, and door switch, still no change.
I'm guessing the control panel is pooched - any thoughts?
Al
Old June 9th, 2009, 07:31 AM
Its your control panel assembly thats bad, I've seen this happen before, you will need a new one.
Old June 10th, 2009, 05:57 PM
Default Beeping Dryer
Ok - It's a $200 part so I need to ask a couple more questions
I ran the diagnostic tests:
fficeffice" />>>
I got an error code 18, which isn’t even in the manual!?!
I ran the Function Test Sequence and all the function performed normally, and the thermistor seemed to be behaving normally - i.e as the dryer was hotter it gave a higher reading, when the dryer was cool it gave a lower reading.
However I checked the thermstor resistance and it was 60K ohms, while the manual said it is supposed to be 50K +- 10%. Think it could be the the thermistor or still the expensve panel?
Thx
Al
Old June 10th, 2009, 10:27 PM
No, because if it was your thermistor it would only beep when you tryed to start it, not when its off and not running.
Kenmore 417.84152500 dryer Beeping and shutting off crusso Sears Kenmore 8 October 20th, 2008 05:12 PM
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 28th, 2008 10:46 PM
Kenmore Elite Dryer 110.60092991 - Constant Beeping rbusch Sears Kenmore 7 October 21st, 2007 11:59 PM
Kenmore Dryer 110.70052991 lint screen and beeping problem eva Sears Kenmore 2 August 19th, 2005 08:27 PM
Beeping Kenmore Elite Dryer Update mattmorgan64 Sears Kenmore 1 February 23rd, 2005 09:06 PM
