Results 1 to 4 of 4
Thread: freezer works fridge does not
    ickabod is offline Premium Member
    Jun 2009
    alaska
    Default freezer works fridge does not
    I have a kenmore elite 106.50593003.
    It suddenly stopped working all together. I replaced the start relay and now the freezer work but not the fridge. There is no cold air coming from the vents in the fridge side. Also is there a place to get an exploded view of the appliance. thanks
    When you open the freezer door do you hear the evaporator(freezer) fan running?
    Thats what blows the cold air from the freezer into the refrigerator section.
    You can look at your refrigerator parts diagrams at http://www.searspartsdirect.com/part...t/index.action
    Jun 2009
    alaska
    Thanks for the reply. I do hear a fan in freezer. After 24 hr's on a setting of 8 (Max 9) with no food fridge temp at 50 degees F????????. During repairs unit was unplugged for a day of two dont think i have ice blockage.
    Ok, thats very odd, I've changed hundreds of those start relay's with no problems, you may have a sealed system/compressor problem then, check your evaporator coils and see if they ALL have a thin layer of frost on them.
    To access the coils, take everything out of your freezer and take off the lower back access panel inside your freezer, should have about 4 screws holding in place.
  1. [FIXED] Kenmore - Freezer works, Fridge doesn't
    By Scarlett in forum Sears Kenmore
    Last Post: May 2nd, 2009, 09:19 PM
  2. Replies: 1
    Last Post: September 2nd, 2008, 10:28 AM
  3. freezer works fridge doesn't
    By Squirrrlly in forum Sears Kenmore
    Last Post: November 1st, 2007, 07:46 AM
  4. Kenmore Coldspot freezer perfect, fridge warm
    By nandof in forum Sears Kenmore
    Last Post: July 1st, 2007, 09:49 AM
  5. Replies: 4
    Last Post: April 4th, 2006, 12:52 PM
