Old June 20th, 2009, 12:51 PM
powercat7 is on a distinguished road
Default [FIXED] 80 series won't agitate
I have a Kenmore washer model# 110.24872300. The machine will not agitate. However, it will spin and drain. Also, water leaks from the tub when it should be agitating. Any suggestions on causes and what to do?
Old June 20th, 2009, 09:18 PM
Its possibly your clear rubber hose that goes to your water level pressure switch thats either broke or came off, I'd check that first.
Remove the 2 screws under both end caps, then pull the console forward, then tilt it back on its hinges.
Or the tube came off from where it goes down to your outer tub assembly.
Here's how to remove the cabinet to check that:
http://www.applianceaid.com/procedures.html#remove
Old June 21st, 2009, 08:02 AM
Thumbs up
Jake-
You were right! The hose came off the outer tub assembly. The machine is fixed and running. Thanks for the help!!! Your directions and the pictures were excellent help.
Thanks again,
Phil
Old June 21st, 2009, 09:28 AM
Excellent Phil, good job finding it was the hose that came off the outer tub assembly and fixing it.
Kenmore Series 80 Whirlpool will spin and agitate but will not let water in for new Wash cycle? journeyonline Sears Kenmore 9 May 9th, 2008 03:07 PM
Kenmore Series 80 Doesn't Agitate JoeY Sears Kenmore 9 October 29th, 2006 07:13 AM
kenmore heavy duty 70, series 110 won't spin, drain or agitate anguyen Sears Kenmore 4 August 24th, 2006 01:57 PM
kenmore 80 series washer no spin or agitate brooklynjim Sears Kenmore 1 August 22nd, 2006 09:56 AM
Kenmore HD 70 Series, wont agitate - trips fuse box? - but will spin if on drain otherjohn Sears Kenmore 8 July 11th, 2006 09:22 PM
