Hello:
Our Kenmore Elite HE3T 110.42922200 has that "takes forever to drain before high speed spin" problem. It does eventually complete the cycle but research here seems to indicate that the drain pump is failing. The pump is also makes much more noise than before so I assume I need Part Number: AP3953640. Just looking to confirm and to ask if the Whirlpool Duet Manual covering models GHW9100L and GHW9200L is the correct reference to use. I might as well take care of this now before it fails completely. Thanks in advance, Skip |
Hi Skip,
It sounds like the water pump is going bad. Here's the water pump for your model: Manufacturer's Number: 280187 Yes, its the same repair manual. Here is the online repair manual for the Duet/Kenmore HE3T: http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf Jake
Thanks! Part ordered. I appreciate the online manual, thank you.
I'll check back when the job is completed. Thanks again, Skip |
Sounds good Skip.
Skip Lincoln (July 7th, 2009) | ||
The new pump did the trick -- went right in.
Thank you! You have saved me two service calls (one recently for the dishwasher and one now for the washer), I really appreciate it! Thanks again, Skip |
I forgot to ask, is there a stack kit for the washer and dryer? I have them on the pedestals but I'm considering stacking the dryer on top of the washer, or is this not a good idea?
Thanks, Skip |
Glad the new pump fixed it Skip.
![]() I'm not sure if there's a stack kit available or not, Sears would know, if you go to you local Sears store they can tell you. If you have a good solid floor(cement floor always the best) then it should be fine. Jake
Thanks Jake.
Skip |
Anytime Skip.
| Kenmore Elite 665.16933000 won't drain after washing | dbsimms63 | Sears Kenmore | 14 | June 6th, 2009 04:34 AM |
| Kenmore Elite HE3 drain problem | ninez | Sears Kenmore | 1 | October 16th, 2007 11:19 PM |
| Replacing inner drain hose on Duet He3T #110.42922200 | leadfinder | Sears Kenmore | 1 | August 9th, 2007 10:37 PM |
| Kenmore HE3T 110.42922200 F02, Drain Pump? | nowhere | Sears Kenmore | 1 | February 11th, 2007 09:42 AM |
| Kenmore Elite He3t model 110.42932200 drain problem | Edwin | Sears Kenmore | 3 | July 6th, 2006 08:50 AM |
