I have a Kenmore Washing Machine Series 80 (model # 110.25842400) that developed a leak this past weekend. SOmewhere between 30 - 60 seconds after a cycle starts the water comes out, and its pouring out.
Any suggestions? Thanks Dan |
Hi Dan,
You'll need to remove the washer cabinet and see exactly where the water is coming from, its either comping from the water pump, or the main tub seal directly underneath the outer tub assembly, or possibly a rubber hose to or from the pump is broken. Here is how to remove the end caps on this design: ![]() Then tilt the console back on its hinges. Unplug your washer first! Read #2 and #4 on how to take the cabinet off and check the pump first: http://www.applianceaid.com/procedures.html Here's the water pump for your model: Manufacturer's Number: 3363394 Jake
Jake - thank you - It would have taken me a lot longer to figure out how to get that thing apart as I would never have guessed that.
So the pump had a leak. I replaced it. Put the whole thing back together (that was apparently a mistake) and started it up for a test cycle (partial, either short cycle or rinse only, not sure) and no leaks. But later during the next cycle my wife noticed water again. Any suggestions before I tear it all apart again? thanks Dan |
Ok Dan,
You'll need to remove the cabinet again to see where the leak is coming from, you can run a complete cycle with the cabinet off while your watching it, just jump your lid switch, Jeff explains how to here: http://www.applianceaid.com/dd_lidswitch.html Jake
| Tags |
| kenmore, machine, series, washing |
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16060-kenmore-washing-machine-series-80-water-leak.html
| Everything about kenmore washing machine manual - Yahoo! | This thread | Refback | September 12th, 2009 06:32 AM | |
| Don't buy a 417.xxxxxx front-load washing machine (Kenmore but built by Frigidaire) | ccadwellx | Sears Kenmore Brand Forum | 1 | February 7th, 2006 05:22 PM |
| Water Leak Kenmore 70 series | Wayne Eaton | Sears Kenmore | 1 | November 29th, 2005 09:48 PM |
| Kenmore 80 Series, Water Saver Model, Draining Problems ? | Honeybee | Sears Kenmore | 1 | November 27th, 2005 07:09 PM |
| Kenmore 80 Series No Cold Water During Rinse Cycle | poweruser | Sears Kenmore | 3 | September 1st, 2005 06:24 PM |
