Old July 14th, 2009, 06:03 PM
daddyo is on a distinguished road
Default Kenmore Ultra not rinsing
I have a 6 year old Kenmore Ultra that just recently started to leave a soap film on the dishes. If you take a plate out of the finished wash and run it under water it will show bubbles. Any suggestions ?
Old July 14th, 2009, 06:25 PM
Whats the model# of your dishwasher? Its located inside the door on the side of the tub frame.
Old July 15th, 2009, 06:20 AM
Default Model #
Sorry I wasn't able to find it by myself. It's a 665.16464300
Old July 15th, 2009, 10:35 AM
Ok, Thanks,
Sounds like you'll just need some dishwasher cleaner for the soap build-up that occurs over the years.
Removes built-up soap scum and discoloration due to iron and other water impurities. Also works great in washing machines, porcelain sinks and porcelain tubs. 3 ounce packet.
Glisten Dishwasher Cleaner and Deodorizer
Old July 16th, 2009, 06:58 AM
Default misunderstood
I think I didn't make my self clear. Our dishes are coming out with a film on them and also visible soap. the tub itself is not the problem.I was thinking more in the line of the control board not putting the D-washer into a rinse cycle. How can I tell if the D-washer is rinsing? If it's not rinsing what can I do to get it to rinse?
Thanks ,
Daddyo
Old July 16th, 2009, 09:23 AM
Ok, from what I understood is the dishwasher complete its entire cycle? and the dishes comes out with visible soap on them, or still in the soap dispenser? and this just started out of the blue?
If this is the case, then its possibly your motor impeller thats stripped causing the water pressure flow to decrease and not allowing full water pressure to be pumped through your spray arms and into the soap dispenser and dishes to clean them off properly in rinse.
Here's the motor assembly for your model you can order:
8534942
Here's the complete sump/motor assembly, with the motor already installed:
Part#8268422
Sump and motor assembly
But first check your chopper screen, as some members have reported that screen being clogged up and causing this problem as well:
From the repair manual read Page 17 Read 1-4 where it says this:
Lower Spray Arm
It shows how to get access to the chopper screen and check valve.
Kenmore Ultra Wash III soap door won't close-Spring Help drewty Sears Kenmore 7 November 30th, 2006 10:30 PM
Kenmore Ultra Wash, Need Help Please jacin Sears Kenmore 3 March 26th, 2006 12:03 AM
Kenmore Ultra Dishwasher Main Wash Door DSouza Sears Kenmore 3 November 27th, 2005 05:21 PM
Kenmore Ultra Wash 665 amyjane Sears Kenmore 5 September 29th, 2005 10:41 PM
Kenmore Ultra Wash - not draining DaveT Sears Kenmore 5 September 24th, 2005 04:32 AM
