Old July 29th, 2009, 07:01 PM
loudej is on a distinguished road
Default Installing clock/brain in 790.78863800
A while ago the oven portion of our 790.78863800 stopped heating beyond a slightly warm temperature. A person came to the house and informed us the clock/brain needs replacing. We've order a replacement, part 316418703, but I'm wondering if there's a proper way to install it.
So far I've removed three machine screws from the upper back of the range but the panel they held is still firmly attached. Instead of trying to unscrew and pry loose everything I can reach, are there service manuals or repair manuals available? Or do you know what steps you would go through?
Thanks in advance,
Lou
Old July 29th, 2009, 10:47 PM
Hi Lou,
Its fairly easy to replace, just remove the upper rear access panel#1 here:
http://c.searspartsdirect.com/lis_pn...3052-00001.png
Take all the screws out thats holding in place, Unplug your range first!
Then once its removed you can see the clock assembly from the back, just remove the wires from it, make down on paper where they go, then take the 4 screws out that hold the clock in, then take off the faceplate, just un-peels off, then put it on the new one, and mount the new clock back in place and put the wires back on in the proper place, then put the upper rear access cover back on, thats it.
Old July 30th, 2009, 08:37 PM
That was very easy. Unfortunately, it doesn't look like that was the problem.
Strange thing - after turning the oven on to 350 at the back of the stove-top there seems to be a lot of heat venting onto the surface. Almost seems hotter there than in the oven itself.
Is there something like a vent on a temperature sensor that could be stuck open? Or could it be some sort of seal that's broken letting the heat vent out through the body?
Old July 30th, 2009, 09:54 PM
The oven vent is #36 here:
http://c.searspartsdirect.com/lis_pn...3052-00003.png
There isn't any shutter on it, so I don't know why yours is doing that.
Ok, when you turn your oven on, look inside the oven at the very bottom, do you see an orange glow, but don't hear the gas coming out to start the flame?
It sounds like your oven igniter may be the cause.
Here's the oven igniter for your model:
Manufacturer part number 316489400 is RepairClinic item number 1197384
316489400
Old August 4th, 2009, 07:12 PM
It's interesting to see what sort of structure is allowing that heat to come out onto the surface. Sounds like that's normal - just never noticed it before looking into these problem.
The bottom of the stove does glow and sounds like it's burning gas, and sounds like it's turning itself off and on periodically. We tried setting higher temperatures and it did seem to make a difference, though it was always at least hundred degrees cooler than it should have been.
We also just tried replacing the thermal sensor, part #37 on that diagram, since it wasn't too expensive. Kind of early to say but I think that made a difference.
Thanks again,
Lou
Old August 4th, 2009, 08:59 PM
Ok Lou, keep me posted on this.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16171-installing-clock-brain-790-78863800-a.html
Posted By For Type Date
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback September 15th, 2009 03:04 PM
installing an Amana control panel gellegirl Amana 5 November 17th, 2008 02:30 PM
Unusual question of the day: installing a touchscreen ... cocooner GE/Hotpoint 3 September 15th, 2007 06:21 PM
Installing hard start kit charles Whirlpool 4 January 7th, 2007 10:05 PM
Installing hard start kit charles Whirlpool 5 January 1st, 2007 10:37 PM
3M800 red sealant for installing tub seal 3fordasho Amana 3 April 16th, 2006 09:42 AM
