Old August 5th, 2009, 10:25 AM
tolobill is on a distinguished road
Default kenmore 665.92012100
hello, new guy here and have a little problem. on the left front big burner it starts to heat then never gets hot all the way, also the orange light on the top panel stays lit all the time, this for this burner, thanks.
Old August 5th, 2009, 04:17 PM
Ok, you will need a new front-left burner assembly.
Here's the front-left burner assembly for your model you can order:
Manufacturer's Number: 8523692
8523692
Old August 5th, 2009, 05:52 PM
ok, i will order. will that make the light go out, i dont want to spend a lot of money. if i canr repair for a 100 dollars or less i should buy a new one, what do you think. thanks for the qiuck info.
Old August 5th, 2009, 09:23 PM
The new burner will fix the light staying on issue as well.
Yes, I wouldn't spend much over $100 to fix it.
Old August 6th, 2009, 06:44 AM
great thanks for the info. next question how do i replace it thank you.
Old August 6th, 2009, 09:20 AM
Under the front lip you should see between 2-4 screws. Just remove the screws, then the whole glasstop lifts up. You may need someone to help you hold it up while you remove the front support bracket#9 here:
http://c.searspartsdirect.com/lis_pn...1024-00001.png
Once you have that bracket removed from the glasstop, you can change the front-left element.
Unplug or turn the breaker off to your range first!
Noisy brand new Kenmore ? dirtydeeds Sears Kenmore 1 June 1st, 2008 09:35 PM
Kenmore 110.42822203 bearing Zebrafive Sears Kenmore 1 March 24th, 2008 10:43 PM
Kenmore 94152 melting synthetic fleece swienke Sears Kenmore 4 December 23rd, 2006 02:16 PM
Kenmore 665.15932000 versus Maytag MDB8751 russell g Sears Kenmore 1 October 17th, 2006 10:21 AM
Another Kenmore with no Heat tickedntexas Sears Kenmore 9 February 6th, 2005 06:05 AM
