Old August 6th, 2009, 06:59 AM
Bville01 is on a distinguished road
Default [FIXED] Clicking Noise
Hello. I have a 2007 Kenmore side by side refrigerator model 106.57032602.
In the past few weeks I've noticed that the refrigerator has begun making a clicking, then a humming,restarting or recycling noise that runs for about 4 seconds, stops, and begins again for about 4 seconds.
It does this repeating,clicking noise for about a two minutes and then stops. It does this a few times a day. The clicking noise is coming from the top inside part of the refrig near the temperature controls. The fan noise is coming from the freezer area.
The fridge and freezer seemed to be working fine until this morning when the fridge didn't seem as cold as normal.
I have read that a lot of these clicking noises come from a bad relay near the compressor. This seems to be coming from the inside, top of the refrig side near the temp controls.
Hope this helps with the diagnosis.
Old August 6th, 2009, 09:30 AM
It sounds like your adaptive defrost control board is bad, its #6 here:
http://c.searspartsdirect.com/lis_pn...4020-00010.png
Its in the temp. control console.
#25 trim just un-snaps, don't worry you won't break it. Get a flathead screwdriver and just pry at a corner then it all will un-snap, and the screws are underneath it.
There should be 2 screws in front and 2 screws underneath that come out and the console with drop down a bit to change it, the defrost control is held in with 2 screws.
Unplug your refrigerator first!
Here's the defrost board for this model you can order:
Manufacturer part number 4388932 is RepairClinic item number 844415
4388932
Bville01 (August 6th, 2009)
Old August 6th, 2009, 11:29 AM
Thanks so much for your help Jake. I ordered the part today and should have it next week. I'll install it and let you know.
Thanks again!
Old August 6th, 2009, 04:33 PM
Jake, the part is due on Tues. 8/11. But now the refrig and freezer have stopped cooling. Any further ideas other than waiting for the part? You still think this is the problem given that the unit is not cooling?
Old August 6th, 2009, 07:11 PM
Yes, since you said the sound was coming from that area, if the sound was coming from the back next to your compressor, then I'd say it was your compressor start device relay.
Old August 7th, 2009, 05:13 AM
Thanks again, Jake.
Old August 7th, 2009, 07:59 AM
Glad to help, to keep your food cold while your waiting for that board, I always advise my customers to purchase about 10 pounds of dry ice, which you can get at most grocery stores.
Old August 11th, 2009, 10:24 AM
Default How to unplug
I thought this was going to be the easy part, but how do I unplug the defrost control from the electrical connections. Doesn't want to come apart and I don't want to break it. Any tricks to it?
Old August 11th, 2009, 10:54 AM
They just pull off, if they seem hard to pull off, just use a flathead screwdriver or needle-nose pliers to pry them off.
Old August 11th, 2009, 11:25 AM
Okay, got them off. I can't believe how much force was necessary. New ADC installed - I'll let you know if it works.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16222-fixed-clicking-noise.html
Posted By For Type Date
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback August 28th, 2009 06:13 AM
Kenmore SxS coldspot 106.44102300 clicking noise haga7583 Sears Kenmore 5 December 12th, 2008 10:47 PM
Clicking Noise EdKell Whirlpool 1 April 25th, 2008 10:24 AM
GE GSC22QGTAWW - Clicking noise water despenser alanjackson7 GE/Hotpoint 3 June 21st, 2007 08:39 AM
GE Refrigerator is not working (clicking noise) Tha99 GE/Hotpoint 4 February 16th, 2007 11:07 PM
spin cycle starts with loud clicking noise Kenmore 80 k5er Sears Kenmore 7 September 13th, 2006 10:58 PM
