Go Back   ApplianceBlog.com - Appliance Repair Forums > Appliance Repair Talk > Microwaves > Sears Kenmore
Old August 10th, 2009, 08:37 AM
CaboWabo is on a distinguished road
Default Microwave #665.6061200
Our over the range microwave(Kenmore) just started making a loud continuess grunting noise. It is not a grinding noise. It sounds like something is stuck. The clock, light, and everything else seem to be working
The turntable spins, but very very slow.
I took the bottom panel off and took the turntable motor out, plugged it back in and turned it on, and it still made the noise, but it was coming from inside, and not the motor.
I am not sure if it still heats. I do not want to run it for more than a few seconds, I am affraid it might blow up..lol
Any help on this ?
Ty
Michael..
Old August 10th, 2009, 01:49 PM
I Took the face plate off( Number/start control ). to get a better look inside.
The sound is coming from the top right corner of this model. According to the tech sheet i have for it, it looks and sounds like it is the " Magnetron Themostat ". I don't know, I'm not the expert, but the sound is coming from that area.
Is this an expensive fix?
Can I buy the part and possibly fix it myself ?
Where can i buy the part at ?
ty
Michael..
Old August 10th, 2009, 05:15 PM
I don't work on Microwaves, but I'll ask TechnicianBrian if he can assist you.
Old August 12th, 2009, 06:47 AM
TechnicianBrian's Avatar
Based on your description and the area of the noise, I would suspect either the high voltage diode has failed, and/or the magnetron. If you attempt to cook something, the unit is most likely not heating anymore, or heating intermittantly. The repair isn't difficult, but does take some time and assistance as the unit needs to come off the wall and the cover removed. The magnetron can be expensive to replace, but they are often times covered by a 5 year warranty so if the unit is young enough, you may want to call for service. Parts can be purchased online and locally from many sources if you go at it yourself.
TechnicianBrian
AllTechAppliance.com
Over the Range Whirlpool microwave not working 1der Microwaves 6 June 8th, 2009 11:30 AM
Ewave Microwave Oven bparke20 Microwaves 1 April 13th, 2009 04:23 AM
Dacor 2004 Microwave Model # DMT2420S ginawg Microwaves 0 November 29th, 2008 09:47 AM
Microwave Using Tips nancypeterson Microwaves 0 July 30th, 2007 03:31 AM
Frigidaire Gallery Series Microwave coloradoconsumer Microwaves 1 July 10th, 2007 07:16 PM
