August 10th, 2009, 07:08 PM
[FIXED] Kenmore Elite HE3 -- E1 Error
Hi. We have an electric Kenmore Elite HE3 and for some time now it has been intermittently showing an E1 error and stopping in the middle of a drying cycle. Lately it's been getting worse -- it almost never completely dries the load without being restarted multiple times.
I'd be very grateful for some advice about where to start in terms of troubleshooting, replacing parts, repairing, etc.
Here are the details:
Model: 110.82822101
Serial: ML4204112
Type: DADT-ELE-2406028-EL54
Thanks very much! -Glenn
August 11th, 2009, 09:09 AM
Hi Glenn,
E1 means:
Thermistor Failure. You will need to replace this.
Manufacturer part#8577274 is RepairClinic item#1181075
8577274
You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #32 screws, and remove the #2 screw at the very bottom of the duct assembly with a bracket#11 attached to it, remove that one also. Unplug your dryer first! Then your thermistor is #42 on the blower housing, next to your thermal fuse#59.
August 12th, 2009, 08:32 AM
August 12th, 2009, 09:06 AM
Glad to help.
August 27th, 2009, 08:28 AM
Hey Jake:
I just wanted to let you know that the thermistor seems to have completely corrected the problem. My wife is thrilled! Thanks again for the great help and service.
-Glenn
August 27th, 2009, 09:59 AM
Excellent Glenn, good job.
May 20th, 2011, 06:31 AM
I have had this E1 error code for quite awhile on my Kenmore HE3. Mod 110.92832100.
Sometimes it works just fine, sometimes it runs for a very short time then stops, clothes still wet/damp, giving the error code E1. (I've put off this repair for about 3 years)
I fixed the problem with a new thermistor (Exact Replacement Part # 8577274).
This is a very easy fix. You remove the front lower panel from the dryer (Two 1/4" head sheet metal screws at the very bottom of the dryer - front) then remove the old thermistor (same size screw head) which is located behind the chute where the lint screen sits, on the blower exhaust housing.
You can easily see the thermistor with a flashlight, and it is kind of a blind reach. I used a ¼ drive socket ratchet and was able to loosen and remove the 2 thermistor screws fairly easily.
(Note-there is an excellent video online showing the location of the thermistor. This video wants you to totally disassemble the dryer (remove whole front and drum) to replaced the thermistor. This is NOT necessary. )
The old thermistor is black - part # 3976615. It is shaped sort of like a caplet pill stuck sideways on the plastic bracket.
The new replacement is white - part #8577274. It is shaped like a large teardrop hanging down from the bracket.
I did remove the old thermistor while thoroughly cleaning the lint out of the bottom , inside of the dryer. The old thermistor was coated with caked on lint. I cleaned and reinstalled it while waiting for the new one to arrive. The dryer worked fine AFTER I cleaned the old thermistor! The lint accumulation may explain the erratic function of the thermistor.
I could see small hairline cracks in the old thermistor and I managed to crack off one of the screw tabs (very brittle from the heat).
I believe the shape of the new thermistor will reduce lint accumulation.
Do some online queries and you will find lots of good info.
Hope this helps someone else
Good luck!
April 23rd, 2012, 02:07 PM
Originally Posted by
Leon
...(Note-there is an excellent video online showing the location of the thermistor. This video wants you to totally disassemble the dryer (remove whole front and drum) to replaced the thermistor. This is NOT necessary. )...
...The old thermistor was coated with caked on lint. I cleaned and reinstalled it while waiting for the new one to arrive. The dryer worked fine AFTER I cleaned the old thermistor!
I guess the video shows the removal of the top and drum because you might need the extra room to get at the screw if you're using something with a long handle. My socket/ratchet set has that problem: the socket driver handle (the type that resembles a screwdriver) is too long to fit in the space above the thermistor. I put on my thinking cap and came up with the solution of holding the socket bit in a small vice-grip pliers, so it worked like a small socket wrench. Not too difficult, and much easier than removing the drum. (Especially because my dryer is mounted on top of the washer!)
And thanks very much for the info about removing, cleaning, and replacing the thermistor!
I have been getting the E1 error for a couple months. The clothes get dry, but only on "no heat" cycle. I was ready to buy a new thermistor, when I read the post about cleaning it. I figured I'd give it a try. It couldn't hurt to try, and even if it didn't work, it would test whether I was able to install a new one if need be.
I removed the thermistor, and found it was caked with super-fine lint. Not a lot, but it was pretty densely packed where it had accumulated. I cleaned the thermistor with a soft toothbrush and a small amount of rubbing alcohol. Then I re-installed it and let it dry overnight. I tried it the next day, and .... Bravo! The dryer has been working perfectly for several loads since I cleaned the thermistor! This is great! I love to save money by doing these small repairs myself.
August 30th, 2009, 03:50 PM
By cdmom in forum Sears Kenmore
Last Post: November 29th, 2011, 11:38 PM
By cyclingdude in forum Sears Kenmore
Last Post: October 29th, 2006, 07:53 PM
By imprincess2h in forum Sears Kenmore
Last Post: October 3rd, 2006, 09:54 AM
By Westerberg in forum Sears Kenmore
Last Post: September 9th, 2006, 10:52 AM
By jbaggins in forum Sears Kenmore
Last Post: January 10th, 2006, 04:24 PM
Tags for this Thread
