Old August 12th, 2009, 04:08 PM
Michael37 is on a distinguished road
Default Kenmore Ultrawash 665.17621691 Should I replace this damaged part?
Hi, my machine started leaving residue and not completely draining so I got to this part which appears to be damaged.
Am I right in thinking that this is somehow affecting the water draining? I have already checked all the filters and screens as well as the check valve and hose and there are no clogs.
Any help would be appreciated. I figure I need to replace this part? Or is there something else that I should check? This is a wonderful site that got me this far already! Thanks!
As my title suggests, I am trying to figure out if I can replace this or I ahve to replace the whole motor meaning that I should just buy another one of these used (since I got it for 60 dollars).
Kenmore Ultrawash 665.17621691 Should I replace this damaged part?-dishwasher-1.jpg   Kenmore Ultrawash 665.17621691 Should I replace this damaged part?-dishwasher-2.jpg
Old August 12th, 2009, 05:23 PM
Yes, you will need to replace that part, turn the motor shaft to make sure the motor turns freely first, if it doesn't then you would need to order the pump/motor assembly complete.
Here's the impeller kit for your model you can order:
Manufacturer part number 675806 is RepairClinic item number 679717
675806
Here's the motor/pump assembly for your model:
Manufacturer's Number: 675793A
Old August 12th, 2009, 07:22 PM
Thanks Jake!
Do I need any special tools? How do I get that gray piece off there? Is that what people are talking about breaking off?
Old August 12th, 2009, 09:51 PM
Yes, it should just pull up, if its stuck on you'll probably have to break it off.
Jeff explains here how to do it:
http://www.applianceaid.com/dishrepairhelp.html
Old August 20th, 2009, 12:58 PM
Hi Jake,
I finally got the kit here and I have this extra part here that isn't in the instructions! Any idea what it is and where it goes?
Old August 20th, 2009, 05:39 PM
Look at the #24 box here:
http://c.searspartsdirect.com/lis_pn...2892-00004.png
It goes under that gray lower impeller.
Kenmore Elite Glass top - Inner part of three part burner not working alwaysxring Sears Kenmore 3 March 18th, 2009 01:16 PM
[FIXED] Replace damaged cooktop? Freddeiss Frigidaire/Tappan/Electrolux 7 November 15th, 2008 03:06 PM
Kenmore heavy duty 70 washer lid latch part order? top_five Sears Kenmore 1 March 13th, 2008 09:44 AM
kenmore he3t door wont lock part replaced to no avail! timwbond Sears Kenmore 3 August 2nd, 2007 09:42 AM
Damaged Water Supply Line - Repair or replace? TitansFan Sears Kenmore 3 November 2nd, 2006 10:34 PM
