Old August 16th, 2009, 05:37 PM
BAJ BAJ is offline
BAJ is on a distinguished road
Default Ice Maker Jamming
We purchased a 106.5890*801 last Fall. Our ice maker has quit (jammed) several times and seems to be getting more frequent. When it happens, we have to open the ice cube maker door and pry the rogue cube loose.
Since it is still in the first year, we had a service tech out. He said it could be due to not cleaning the ice bin (in the door) frequently enough which can frost up the maker (not in the door - huh?), or low water pressure (we had 60psi several years ago when we had our sprinkler system installed), or possibly the shutoff valve and supply line. I would guess it's probably the last one, because it's just a needle valve and a very small diameter flexible copper line.
I'm considering replacing the shutoff valve and supply line. I estimate the length of the run is probably 30'-35'. What size line would be recommended for this length?
Any other things I should check before digging into the plumbing?
-Brad
Old August 16th, 2009, 09:21 PM
Yes, its likely the low water pressure, I've seen many of those needle valves work for awhile then clog up. Having a regular valve is much better.
1/4" is fine for that run.
Old August 17th, 2009, 08:00 PM
BAJ BAJ is offline
Thanks for the info. Yeah, I'm not a big fan of the saddle/needle valves. I know they are easy to install, but it seems they end up causing more trouble down the road.
I was thinking of going with a larger line (the basement is unfinished, so it wouldn't be too hard) to try to increase flow from the water dispenser as well. Do you think this would help, or is the flow restriction likely elsewhere (the needle valve or in the fridge itself)?
-Brad
Old August 17th, 2009, 09:20 PM
You can run 5/16" but you would need a reducer to 1/4" when it connects to your water inlet valve in the back of your refrigerator.
Old August 18th, 2009, 07:42 PM
BAJ BAJ is offline
Cool, thanks again!
Old August 18th, 2009, 10:56 PM
Glad to help Brad.
Old August 24th, 2009, 10:54 AM
BAJ BAJ is offline
For anyone interested, I replaced the saddle valves with larger ball valves. I don't know if this will cure the ice maker jamming issue, but the water flow through the fridge dispenser has improved dramatically and I can really hear the ice maker fill now (had never really noticed the sound of water before).
Thanks for the tip Jake, it was nice to not have to replace the 1/4" line.
Thanks again,
-Brad
Old August 24th, 2009, 11:04 AM
Good job Brad, glad to help.
Tags
ice maker, jam, kenmore
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16308-ice-maker-jamming.html
Posted By For Type Date
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback August 25th, 2009 05:16 PM
[FIXED] Kenmore Elite Ice Maker and Ice Dispenser not working honarvar Sears Kenmore 10 July 16th, 2009 06:17 PM
Ice Maker just quit osucowboy Whirlpool 3 January 3rd, 2009 08:15 PM
