Old August 21st, 2009, 02:33 PM
vcimav is on a distinguished road
Default 665.17033402 leaking after new motor and sump
I followed multiple threads to remove my pump and sump and replace.
It's all replaced and hooked back up except I now have a leak somewhere underneath at the drain pump. I tried to look at a scematic to identify the actual part name. but the drain hose connect into that part.
It's either that part or the one behind which I think is the pump.
Old August 21st, 2009, 03:34 PM
Is it this part:
Part#8542575
Pressure switch
Make sure the o-ring is in place, read this thread here:
http://www.applianceblog.com/mainfor...ad.php?p=63306
Old August 22nd, 2009, 06:24 AM
Yes that is the part. pressure switch, I removed and put the o ring and cleaned then put back in place.
started back up and it's leaking from that part.
As It was draining and leaking I was able to push that part in and stop the leak.
So my options are probably
Buy a new pressure switch
buy a new o ring
or can i pipe glue that part in place. I would think that would prevent removal of motor in the future?
Old August 22nd, 2009, 06:41 AM
here are snapshots of my part, it looks a little different and wondering if those indentations are normal.
665.17033402 leaking after new motor and sump-img_9874.jpg   665.17033402 leaking after new motor and sump-img_9878.jpg   665.17033402 leaking after new motor and sump-img_9879.jpg
Old August 22nd, 2009, 09:26 AM
It does look slightly different, but I doubled checked your model# and the part I posted of the pressure switch above is correct for your model.
Seems that part is on back-order at all the online appliance part stores as well, and unfortunately they don't make the o-ring a separate part you can purchase only.
You may want to take that o-ring to you local hardware or plumbing store in your area to see if they can match it up.
Old August 22nd, 2009, 11:12 AM
Default Fixed
took the o ring to hardware store they had a few drawers of parts to search various sizes. Found one similar and it worked.
Ran a cycle no leaks.
Thanks for your site.
Old August 22nd, 2009, 11:48 AM
Excellent, good job.
