Old August 24th, 2009, 05:29 AM
docleon is on a distinguished road
Default kenmore limited edition
I have a kenmore limited edition gas range model 36275944100. When I try to preheat the oven, it will begin to heat but never reaches the desired temperature. All other areas work fine. Any ideas? Thanks
Old August 24th, 2009, 08:24 AM
It could be the oven igniter is starting to go bad.
Try leaving the oven door open and start the oven, then look at the bottom for an orange glow, if it does not fire up the gas in 90 seconds but its glowing, its likely your igniter is bad.
Manufacturer's Number: WB13K21
WB13K21
Refridgerator Installation - Kenmore to Kenmore sard Refrigerators & Freezers 1 August 11th, 2009 05:45 PM
Kenmore Limited Edition Motor Replacement ginky4 Sears Kenmore 3 April 22nd, 2009 09:46 AM
Limited Edition by Kenmore 110.82694540 - PF filipm Sears Kenmore 2 September 26th, 2007 09:52 AM
Kenmore 94152 melting synthetic fleece swienke Sears Kenmore 4 December 23rd, 2006 02:16 PM
Another Kenmore with no Heat tickedntexas Sears Kenmore 9 February 6th, 2005 06:05 AM
