Old August 25th, 2009, 10:56 AM
hrk hrk is offline
hrk is on a distinguished road
Default [FIXED] Kenmore He3 No Heat
About a month ago the dyer had lowo heat so I pulled the top and rear covers off and cleaned out the dryer, packed with lint, and we're working on getting the ducting to the roof professionally cleaned out. Unless you have any idea on what to use to clean it out..
Yes I removed the plug from the power source.... Checked my fuse box, all fuses are properly set..
It is a Kenmore He3t electric dryer with 110.848xxxxx as the model number. I will update that number when I get home.
The Dryer was working fine but we noticed longer drying times so presumed it was not creating much heat which is the reason I pulled the top and rear panel, after cleaning it worked fine for a couple of weeks.
Now we have no heat at all but everything else works and I have no error codes on the panel. On the control all lights and buttons work, dryer will start, drum turns, interior light works, just zero heat.
Pulled the front lower panel and the vent down tube, cleaned it as well, with my meter checked the Thermal fuse by pulling one wire and checking Ohms for continuity or 0 and that registered correctly at 0.
Next I checked the heater block , disconnected one terminal, and using the same meter at the same setting and it stayed at infinity, no Ohms reading changed which per the manual should be 7 to 12?
I have yet to check the Thermal Cutoff or High Limit Thermostat switches.
What else should I check? it appears maybe the heater unit is inoperable?
The lint was scorched some that I took out of the heater unit.
Need to get this thing rolling before I get tossed out
Old August 25th, 2009, 03:17 PM
hrk hrk is offline
Model is 110.84832200
Old August 25th, 2009, 04:06 PM
Its likely going to be either the heater itself or the thermal cut-off thats mounted on the side of the heater housing.
Check those for continuity when you get home, make sure you unplug your dryer first.
And please post your full model# as well when you get home.
Old August 25th, 2009, 04:18 PM
I deleted your other thread.
Ok, thanks for posting the model#.
Ohm those 2 parts for continuity now.
Your thermal cut-off#47 here, heater #14 here:
Here's the thermal cut-off#47 for your model:
Manufacturer part#279973 is RepairClinic item#897710
279973
Here's the heating element#14:
Manufacturer part#3387747 is RepairClinic item#525502
Old August 25th, 2009, 06:50 PM
hrk hrk is offline
Jake, thanks here are the results..
thermal cut off was .3 when set at 200 on the meter
same for the high-limit .3 at 200
I get infinity or a 1 on the heater terminals same 200 on the meter
Old August 25th, 2009, 07:04 PM
Touch your meter probes together on 200 on the meter and tell me what you get.
Old August 26th, 2009, 05:35 AM
hrk hrk is offline
Nice weather looked good, betcha had a great time.
Old August 26th, 2009, 08:24 AM
I wanted to see what your meter reads when you touch your meter probes together, so I can see if your readings were, as all meters are different.
Some common tips...
http://www.applianceaid.com/test_with_ohmmeter.html
http://www.applianceaid.com/whirlpoo....html#no-eheat
0 is continuity
Old August 26th, 2009, 08:37 AM
hrk hrk is offline
wrong forum don't know how that happened I'll have the reading after lunch.
Old August 26th, 2009, 09:14 AM
hrk hrk is offline
reading crossed at 200 is .3 so it shows continuity as thats probably the resistance of the wires on the digital MM
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 28th, 2008 10:46 PM
Kenmore electric dryer does not heat. fiabeg Sears Kenmore 3 June 3rd, 2008 08:22 PM
Kenmore Elite HE3 Gas Dryer No Heat billjes Sears Kenmore 1 June 26th, 2007 08:27 AM
Even Heat Board Fried in Kenmore Elite 110.73942101 caliamara Sears Kenmore 4 December 10th, 2006 08:55 AM
