September 10th, 2009, 01:52 PM
Kenmore 110.27062602 washer
this kenmore washer stops at the end of most wash cycles with 12 minutes left on the timer with a uL error code. If start is pressed again it may reoccur or sometimes it will finish the cycle. I only looked at it briefly, but I'm suspecting its the drain pump
September 10th, 2009, 07:52 PM
I wish I could help you on this, but I quit Sears just before the Oasis models came out, and haven't had the training or chance to work on any.
Here's the tech. sheet for it:
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
Hope that helps.
September 16th, 2009, 06:14 AM
what I've done
ul means unbalanced load, got into diagnostics and pulled I believe a 51 which is the rps. Since this a known weak point, I replaced it along with the new harness kit. I'm sure the computer determines an unbalanced load using info from the rpg,but the problem persists. I'll post my progress. Any feedback would be appreciated Dave
September 21st, 2009, 06:47 AM
still not fixxed
I've now replaced the motor control board. It worked fine for a couple times, I just got a call that uL is showing up again, kind of lost, but I'll post my progress, thanks
David
July 28th, 2010, 01:01 PM
Hi David, did you ever resolve this issue?
By Lewis-the-dog in forum Sears Kenmore
Last Post: January 22nd, 2012, 04:09 PM
By top_five in forum Sears Kenmore
Last Post: January 9th, 2008, 11:30 AM
By Stinger44 in forum Sears Kenmore
Last Post: December 7th, 2007, 06:57 PM
By gerifalte in forum Sears Kenmore
Last Post: November 1st, 2006, 01:31 PM
By mvmartin in forum Sears Kenmore
Last Post: February 10th, 2006, 12:40 AM
