LinkBack (2) Thread Tools Search this Thread Display Modes
  2 links from elsewhere to this Post. Click to view. #1
Old September 12th, 2009, 07:44 AM
phrabs is on a distinguished road
Default [FIXED] 665.95179300 Bake/Broil Not Working-Pictures
Kenmore Triple Task Freestanding Range.
The bake and broil went out after my wife had put the oven through the cleaning cycle (which did not work). My wife said she had smelled a faint electrical smell a few times in the weeks leading up to this.
I checked the Display Code, which read E1, F3, which indicates that the Oven Sensor is Shorted. I checked the wires, which appeared to be fine. I checked the bake and broil again and it still did not work. I then replaced the oven sensor as directed by the tech sheet. Bake and broil still do not work.
Went back to the oven to check wiring again. Found what looks to be a short on the back of the board. I have attached some pics - two that show one of the connections that looks burned out, and one that shows where some "droppings" fell from that connection.
I know this may be obvious, but that looks bad. Means I am probably going to need to replace the control board. Would you mind giving me some confirmation on that, or whether I need to check for something else also?
Thanks.
[FIXED] 665.95179300 Bake/Broil Not Working-Pictures-kenmore-pic-1.jpg   [FIXED] 665.95179300 Bake/Broil Not Working-Pictures-kenmore-pic-2.jpg   [FIXED] 665.95179300 Bake/Broil Not Working-Pictures-kenmore-pic-3.jpg
Old September 12th, 2009, 10:33 AM
Yup, Its your control board you would need.
Here's the control board for your model you can order:
Manufacturer part number 8524346 is RepairClinic item number 1028048
8524346
Old September 12th, 2009, 10:58 AM
Thank you for your help. I will order the board and hope for the best.
Old September 12th, 2009, 11:12 AM
Old September 14th, 2009, 03:57 PM
Got the board today. Just to be safe, since this thing is not cheap ... what advice do you have in installing it. I figured the advice you give would be helpful to some other people, too.
Thanks again for all your help.
Old September 14th, 2009, 06:51 PM
Pull your range out from the wall, Then unplug your range , then take off the upper back access panel, then mark down on paper where you take the wires off the old board, then unmount the old board, should be about 4 screws around it.
Then install the new board and put the wires back(should be same location) then install the back access panel and your good to go.
Old September 16th, 2009, 07:22 PM
Ok. I am feeling not very smart now. How do you get the Control Panel unmounted? I am not seeing any screws. All I see are silver clips that seem to be holding this thing on. I am sure this is painfully obvious, but dawg-goned I ain't seeing it.
Can you provide some more detailed advice on unmounting this puppy?
Thanks.
Old September 16th, 2009, 10:35 PM
Ok, then you should see plastic clips that you can push-in then I believe the control board will slide and pull out.
Old September 17th, 2009, 09:49 AM
I don't see any plastic clips, but there are several metal clips that protrude through small slots (see the attached picture). It appears that you would have to bend the little clips, but I am concerned that they will break if I bend them. They don't seem too terribly sturdy. However, I can't see another possible way to get this board off.
I hope there is not a crazy easy solution to this that my eyes are just not seeing. Thanks again for your help!
[FIXED] 665.95179300 Bake/Broil Not Working-Pictures-kenmore-pic-4.jpg
Old September 17th, 2009, 10:33 AM
Yes, you just bend them even with the slots in the control board, don't worry you won't break them.
Then the control board slides out.
Tags
kenmore, triple task
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16550-fixed-665-95179300-bake-broil-not-working-pictures.html
Posted By For Type Date
Appliance Blog Forums | Site profile | BoardReader This thread Refback September 19th, 2009 03:46 PM
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback September 16th, 2009 02:38 PM
[FIXED] Whirlpool Ikea Oven - Bake/Broil Not Working Izumino Whirlpool 5 June 23rd, 2009 03:01 PM
[FIXED] Kenmore 106.565434 freezer ok/ref not working mschriskim Sears Kenmore 3 June 3rd, 2009 09:57 PM
Maytag MER5755QAW oven not working kristinaks Maytag/Magic Chef/Admiral/Jenn-Air 9 May 28th, 2009 08:46 PM
Whirlpool side-by-side refridgerator ice maker not working... bclampff Whirlpool 5 March 13th, 2007 08:53 AM
maytag s/s freezer not working fridge is fine reiavt Maytag/Magic Chef/Admiral/Jenn-Air 1 September 13th, 2006 11:15 PM
