Old September 21st, 2009, 02:04 PM
sandcave is on a distinguished road
Default kenmore series 90 agitates but won't spin
My kenmore series 90 washer fills, drains, and agitates, but won't spin in rinse or spin cycle. It would spin after we would open it and give it a "push" (hand-spin it a couple of times), but now it won't spin at all. I took off the coupler, and that looks fine (not chipped, broken, or worn). What else could it be? And are other potential problems easily repaired? Thanks,
Dave
Old September 21st, 2009, 04:57 PM
Hi Dave,
Whats the model# of your washer? Its located under the lid.
So in rinse spin and final spin you can hear the motor running but doesn't spin at all now?
If thats the case, its likely your basket drive/clutch assembly you will need to replace.
Old September 21st, 2009, 05:07 PM
Default kenmore series 90 reply
model # 110.23922200.
Can a beginner/novice make such a repair? How can I know for sure? How much? Thanks,
Dave
Old September 21st, 2009, 05:39 PM
I used to run into alot of these that did this Dave.
Yes, its quite a job to do, don't know if you want to do it for a beginner/novice.
How old is your washer? If you don't know post the serial# and I can tell you.
Here's the thread about how to access the basket drive/brake assembly:
Whirlpool, Kenmore, Roper, Estate, Kitchen Aid: Direct Drive Spin Tube
Here is the basket drive for your model:
Manufacturer part number 285792 is RepairClinic item number 1254
285792
Here is your clutch assembly:
Manufacturer part number 285785 is RepairClinic item number 2670
285785
Old September 22nd, 2009, 02:39 AM
It's about 7 years old. I'll check your links.
Dave
Old September 22nd, 2009, 08:55 AM
Ok, then you'd really want to consider looking at purchasing a new washer if you have a large family with more than 4 people in the household using the washer daily or many times a day as other parts are wearing as well.
Old September 22nd, 2009, 11:12 AM
Really? I thought they typically last 10-15 years. We do have 6 in our family, so, yes, it gets abused pretty well. Thanks for your help.
Dave
Old September 22nd, 2009, 03:30 PM
Nope, not anymore unfortunately Dave. Now its about 8-12 years.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16614-kenmore-series-90-agitates-but-wont-spin.html
Posted By For Type Date
Kenmore 90 Series Washer on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback September 22nd, 2009 05:18 PM
Kenmore 417.42052100 - Motor barely agitates, spin needs a "push" neilman Sears Kenmore 7 January 12th, 2009 06:05 PM
Kenmore 80 Series noise during spin with youtube Slow Ride Sears Kenmore 9 December 9th, 2008 05:51 PM
Kenmore Series 80 Washer slow spin jjenkins Sears Kenmore 5 December 15th, 2006 09:21 PM
Kenmore 80 Series 110.24832200 Won't Spin Goldy2005 Sears Kenmore 3 October 15th, 2006 06:54 PM
Kenmore Series 90 agitates, neutral drain OK, but won't spin. Steve Sears Kenmore 18 March 20th, 2005 10:48 AM
