Old September 30th, 2009, 04:10 AM
Wolfie is on a distinguished road
Default Kenmore Elite 106.74202402 icemaker
Hi
I have a two year old Kenmore Elite 106.74202402, with the water in the door and the icemaker just in the freezer. I changed the filter recently. The icemaker makes ice but it doesn't get broken up and pushed out of the maker. I have poured water onto the ice to get it out a few times, but after it forms new ice it won't break up the new ice. This has happened a couple of times before, but it always started up again after I broke up the ice once. Do I need a new icemaker?
Also, when drinks or produce are placed at the back of the fridge, they freeze. Fridge is set at 38, freezer at 3.
Wolfie
Old September 30th, 2009, 07:48 AM
Hi Wolfie,
Yes, its your ice maker thats bad. You will need a new one.
Here's the Ice Maker for your model you can order:
Manufacturer's Number: 4317943
4317943
Adjust the refrigerator control temp one notch warmer.
Old September 30th, 2009, 06:38 PM
Originally Posted by Jake View Post
Hi Wolfie,
4317943
OK thanks. I'm not the handiest guy....how hard is it to install?
Old September 30th, 2009, 08:05 PM
Its fairly easy, you just remove the 2 top screws from the top of it, then it may have 1 screw on the bottom, then once its unmounted you just disconnect the electrical connect to it from the back where it plugs into the inside of your freezer, and thats it.
Then install the new one.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16677-kenmore-elite-106-74202402-icemaker.html
Posted By For Type Date
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback October 2nd, 2009 05:36 PM
[FIXED] Kenmore Elite Side-by-side, Water works, No Ice!! (In door icemaker) Instantaneous Sears Kenmore 5 June 20th, 2009 09:38 PM
Kenmore Elite Coldspot Icemaker issue geeray Sears Kenmore 11 April 3rd, 2009 09:40 PM
Kenmore Elite 795.77579600 Icemaker trosanjohn Sears Kenmore 1 November 6th, 2008 03:15 PM
kenmore elite icemaker not working joe pascual Sears Kenmore 1 April 13th, 2008 01:03 AM
Kenmore Elite Icemaker not working david18 Sears Kenmore 1 September 9th, 2006 10:34 AM
