Kenmore Mod: 110 45872404
Sounds like a BB or Something rolling around between the Basket and tub. You can hand spin it and stop it fast and it you can hear rattle around for a second or two. Makes same noise when ever the basket is spinning. How do I get this thing out of there?? Herb |
Hi Herb,
The best way to check is to look through the holes in your tub, get a floodlight or something to see well and check all the holes and feel the holes for objects. If you can't find anything, then its likely you'll need to remove the tub to pump hose#4 here: http://content.searspartsdirect.com/...2001-00006.png by removing the #3 clamp and the drain ball#2 To get access to this remove the front access panel below the door: You first remove the 3 bottom torx screws(all the way at the bottom next to the floor) then Remove the toe panel by lifting slightly and pulling forward. Jake
| Tags |
| rattle |
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16679-object-between-basket-tub.html
| Sears Kenmore on Appliance Blog Forums | BoardReader | This thread | Refback | October 7th, 2009 11:17 PM | |
| Whirl Ult.Care Washer leaves H20 in tub | aphack | Whirlpool/KitchenAid | 5 | July 30th, 2009 08:36 AM |
| Kenmore HE3 basket spins off center | bbrian35 | Sears Kenmore | 3 | April 16th, 2009 08:28 AM |
| [FIXED] want to replace tub seal/bearing | eacharts | Sears Kenmore | 9 | January 4th, 2009 09:42 PM |
| GE - Washer:loud noise when spin.... | Aone | GE/Hotpoint | 11 | January 11th, 2008 11:15 PM |
