Kenmore Model 110.65942401.
I have the same problem others have mentioned. When you push the start button the dryer starts but when you let go of the button the dryer stops - no beeps. I ordered the control board after reading the sticky thread, but that did not fix the problem. One test I have read is to swap the motor relay with the dryer? relay. I can't for the life of me find these two. Where are they? |
Except yours is NOT an even heat dryer....no control board and no relays. That little board is for the moisture dryness only. Quote:
The motor will run if I hold the button in, so I don't think it is the motor or the door switch. Does that also eliminate the broken wire? It seems like it was not drying as well as it on the timed dry cycle. Might the problem be with the thermostat or thermal cutoff? |
| can't find original thread | EricEG | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | March 16th, 2008 09:57 AM |
| Maytag dryer = no heat, can't find model # | omme0004 | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | October 3rd, 2007 09:38 AM |
| Can't find fuse | mambeault | Sears Kenmore | 1 | March 12th, 2006 12:12 PM |
| I am trying to find out if anyone has had any good or bad experiences with .... | Christel B | Frigidaire Brands Forum | 2 | January 17th, 2006 06:35 PM |
| F-1 error, can't find model # | bbqueen | Sears Kenmore | 0 | August 8th, 2005 11:44 AM |
