Old October 2nd, 2009, 10:41 AM
DKN DKN is offline
DKN is on a distinguished road
Default [FIXED] Kenmore Coldspot model 106.53364300 stop working
I have a Kenmore S-by-S Coldspot 106.53364300 for about 5 years. Yesterday the fridge stop working, no cold air on both freezer and fridge side. At the same time, the control panel on the fridge side (adjusting temperature for the freezer and fridge) is stuck at the middle (cannot adjust at all). From what I've bee reading, it may be the start relay issue. I've not had a chance to trouble shoot it yet. Anyone have the same/similar model with same issue? All advice is very much appreciated.
David
Old October 2nd, 2009, 12:16 PM
Hi David,
First unplug your refrigerator for about 5 minutes to see if the control will reset, if it doesn't then you will need a new temp control board.
Here's the temp control board for your model:
Manufacturer part number 8201527 is RepairClinic item number 949546
8201527
Old October 2nd, 2009, 12:45 PM
DKN DKN is offline
Hi Jake,
Thanks for the quick reply. Do you know where I can find a diagram showing how to remove the temp control board?
David
Old October 2nd, 2009, 01:15 PM
Here's the parts diagram with the control board in it #6:
http://c.searspartsdirect.com/lis_pn...4007-00010.png
Its located inside your console#1, just remove the #7 screws underneath it and it should drop down so you can remove it.
Unplug your refrigerator first.
Old October 2nd, 2009, 02:00 PM
DKN DKN is offline
I just spoke with my brother and he mentioned that the fridge was service by Sears at the beginning for similar issue (no cold air) while still under warranty. The parts replaced were the thermostat and damper. Do you think a faulty thermostat would affect the temperature control panel not able to adjust up or down? Is there a way to trouble shoot this?
Thanks again,
David
Old October 2nd, 2009, 08:06 PM
No David,
Now way to toubleshoot the temp control board.
Old October 2nd, 2009, 11:37 PM
DKN DKN is offline
Do you know where I can find the electrical schematic for this Kenmore s/s coldspot? I've had a chance to remove the back cover and looked at the start/overload component connected to the side of the compressor. I've attached pictures of the component that rattle when shaken. Hope you can confirm that this is the start/overload relay and whether this should be replace.
Without a schematic, it's difficult to do proper measurement.
David
[FIXED] Kenmore Coldspot model 106.53364300 stop working-img_0556.jpg   [FIXED] Kenmore Coldspot model 106.53364300 stop working-img_0557.jpg
Old October 3rd, 2009, 09:25 AM
Yes, if it rattles, then its broken inside.
Here's the start relay for your model you can order:
Manufacturer's Number: 2319792
Old November 19th, 2009, 04:17 PM
DKN DKN is offline
Just want to provide an update. Replacing the start relay solved the problem, both freezer and fridge are working again.
David
Old November 19th, 2009, 05:59 PM
Excellent David, good job.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/sears-kenmore/16697-fixed-kenmore-coldspot-model-106-53364300-stop-working.html
Posted By For Type Date
Sears Kenmore on Appliance Blog Forums | BoardReader This thread Refback October 8th, 2009 05:41 PM
Kenmore Coldspot - Ice Maker Not Working vik Sears Kenmore 0 November 25th, 2007 10:06 AM
Kenmore Elite Model 790.4660* (stovetop not working) LDJones Sears Kenmore 7 January 24th, 2007 07:41 AM
Kenmore Model 70 electric won't stop rubani Sears Kenmore 4 December 5th, 2006 06:56 AM
Kenmore Model 110.66822694 Won't Stop Running hunter6009 Sears Kenmore 1 March 5th, 2006 10:22 PM
Kenmore Coldspot IceMaker Water Won't Stop richardmcjunkin Sears Kenmore 1 October 10th, 2005 09:23 PM
