Old October 5th, 2009, 09:53 AM
kruser67 is on a distinguished road
Default [FIXED] Kenmore Elite Series 90
I have a Kenmore Elite Series 90, about 11 years old. Model number 110.68932790. The problem that I have has gotten progressively worse in the past months, now the dryer barely runs at all. At first, when pressing the start button, the dryer would run until the button was released, then it would quit. Pressing the button a second time caused a normal start. I don't know if that is related to what comes next. The dryer would not complete a normal cycle. It would run for about 30 minutes whether it was on auto moisture or if it was timed. When it stopped, it would just quit, no end of cycle buzzer. Pressing the start button at that point had no effect, as if it was dead. If I waited a while, I could restart it for another 30 minutes. I noticed that the sounds at start up became abnormal, and now when I start it I get less than five minutes. My assumptions are: the motor runs only on the start windings and is overheating or that there is some other temperature related issue. I don't know what to do first, any suggestions would be appreciated.
Old October 5th, 2009, 10:01 AM
You have the evenheat model, Kenmore made many different models for the evenheat design.
So this thread would apply to you, this is our most popular thread and very long, read through it carefully, it tells you everything to check:
[FIXED] Another Kenmore Dryer problem
You can also do a keyword search for evenheat here:
ApplianceBlog.com - Appliance Repair Forums - Search Forums
It will give you about 50 threads on this as well.
The first thing to do is unplug your dryer, then take the end caps off the console as shown here:
Then remove both of the screws on both sides as shown, then that console will lift forward then tilt up to rest on its hinges. Then check your evenheat control board for burned marks on it.
Tell me what you find.
Old October 5th, 2009, 10:18 AM
I have already taken the end caps off and made a visual inspection, but didn't notice obvious burn marks on the board's front side as installed. Would there be burns on the trace side of the board? Also, I've noticed a smell in the air which is what leads me to believe there is something wrong with the motor, that and the funny sound it makes on startup. If I recall, there is a centrifigual switch in the motor, could that be damaged?
Old October 5th, 2009, 10:28 AM
On either side of the board.
Then its likely the motor thats going out.
Yes, but its not a separate part you can order, it comes with a new motor.
This is a 1997 dryer, not worth putting a $128 motor in it in my opinion.
Here's the motor for your model:
Manufacturer's Number: 279787
279787
Old November 1st, 2009, 07:43 PM
I replaced the motor and that solved the problem. It was a pretty good hassle to get at it, but a pretty easy change out. When I removed the old motor I notices that there was a lot of oil on it but I have no idea where it came from, but it seemd to come from the overload. Anyway, thanks for your advice, it is working great again!
Rick
Old November 1st, 2009, 09:26 PM
Excellent Rick, good job.
Kenmore Elite HE3t softener bibi Sears Kenmore 5 March 22nd, 2009 12:26 PM
Kenmore Series 80 Whirlpool will spin and agitate but will not let water in for new Wash cycle? journeyonline Sears Kenmore 9 May 9th, 2008 03:07 PM
Kenmore elite 90 series leak califix Sears Kenmore 3 November 5th, 2006 10:38 PM
Kenmore 80 Series (110.92582100) Won't Fully Drain... Sir_Brizz Sears Kenmore 1 November 5th, 2006 12:06 AM
Moving a front load washer, Kenmore Elite (110 series) ivette Sears Kenmore 13 September 28th, 2006 12:39 PM
