Old October 10th, 2009, 02:43 PM
robertmagness is on a distinguished road
Default Kenmore Ice stopped and ice collecting at bottom
I have a Kenmore Coldspot 106.54602300 upright fridge/freezer that I purchased in 200 (manufacture date is 2003).
Since we moved it--which I though we did gingerly--from one apartment to another, we've been having ice machine problems. First, the ice machine only intermittently made ice. I would get the ice out and it would make ice again. Then water began dripping from the ice maker. Then water started collecting at the bottom of the freezer. Judging by the flow of the water, it was coming from the back of the freezer, from the vents.
Then, one day, water started coming either from the freezer or for the bottom of the whole unit. We would have puddles in front of the unit. We disconnected the water hose from the wall and the puddles decreased. No water is going to the freezer or the unit itself. But we still get water collecting and then freezing at the bottom of the freezer itself. We have to take out the bottom shelf and thaw it about every two weeks. Then we have to chip out the huge ice chunk from the bottom of the freezer.
I don't know much about repairs. Is this something I can do with a few hours on a Saturday? I can learn and read directions well enough.
Thank you.
Old October 10th, 2009, 09:46 PM
Is the water dripping from the ice maker itself?
For the ice at the bottom of your freezer, you will likely need to take the shelves out of your freezer and take off the lower back panel inside the freezer and defrost all the ice with a hair dryer and hot water and run something down the defrost drain hole.
Old October 11th, 2009, 03:39 PM
Default Water drip
The water drips from the back of the freezer at the bottom of the vents in the back.
What about the ice maker? It doesn't make ice and makes a small groaning mixed with a clicking sound.
Old October 11th, 2009, 08:47 PM
Ok, then yes, your ice maker is bad.
You can order it here:
Complete icemaker assembly
Manufacturer's Part#: 2198597
Old October 11th, 2009, 09:24 PM
Default Thanks
Thanks. I noticed I didn't say thank you on the other post. Sorry about that. But thanks all the same. Ok, some work ahead of me.
Is there a post that describes how to remove the broken icemaker and install the new one?
Old October 11th, 2009, 11:28 PM
Yes,
Here's the instructions TO change the ice maker assembly:
1. Remove the bucket from the door to get some room.
2. Put a piece of tape on the sensor flapper to hold it down so you won't damage it while removing the ice maker.
3. Remove the ice maker service cover door by spreading the two hinge fingers apart away from the center and the door should lift out of the slot.
4. Remove the screw in the right rear bottom side of the ice maker.
5. After removing the screw that cover should lift up from the rear and just work it out from the rear and you see the electrical harness.
6. On the left track the should be a tab toward the bottom which you need to push up.
7. Push up tab and start working the ice maker towards you pulling it out of the track.
8. Careful with the electrical harness in the back as you're pulling out.
9. Disconnect the electrical plug by lifting the clip on the plug.
10. Remove the side cover on the side module by pulling off.
11. Remove the bottom shield by removing the 3 screws on the bottom.
12. To install reverse the order as it came out.
106.52709100 Stopped Making Ice Soon2BeDraggin Sears Kenmore 5 September 2nd, 2009 07:55 AM
[FIXED] Kenmore Elite Ice Maker and Ice Dispenser not working honarvar Sears Kenmore 10 July 16th, 2009 06:17 PM
kenmore 106.53652300 Ice maker stopped working danjhill Sears Kenmore 5 October 9th, 2008 06:52 PM
Kenmore 253 57672790 water & ice stopped light still on rkrans Sears Kenmore 3 July 1st, 2007 08:21 AM
Kenmore Coldspot Ice Maker Stopped Working Izumino Sears Kenmore 5 March 11th, 2007 07:58 AM
