Old October 25th, 2009, 06:28 AM
tobijohn is on a distinguished road
Default Kenmore dryer 11066612691 issue
A couple of weeks ago, I started having problems with the above very similar to the one in the thread below. Additionally, while on, the dryer has a much higher pitch than it normally does. It also sometimes won't start up again until it's cooled down for a spell. From this thread as well as a few other related ones, it looks like the motor is on the way out:
Dryer model 110.66512692 problem
Mention was made that in the above thread that it might be wise to consider the purchase of a new dryer rather than replace the motor as other parts might also be near failure. Considering a new Kenmore 7.0 cu. in. dryer is around $400, does it make economic sense to be pro-active and replace those parts along with the motor or would it be better to just buy a new one? TIA...
Old October 25th, 2009, 07:40 AM
Also, if it does make sense to buy a new dryer rather than repair this one, does anyone know what the 60 series capacity actually is? I called Sears and they had no idea....
Old October 25th, 2009, 08:11 AM
Basically all dryers have the same capacity, except for the compact miniature dryers.
How old is your dryer? If you don't know post the serial# and I can tell you.
Old October 25th, 2009, 08:47 AM
Thanks for the prompt response. Serial number is MG4301735. I believe the previous owner purchased it in 1996-97....
Old October 25th, 2009, 10:26 AM
Thanks, Its a 1997 model. Yes it would be to your adavantage to replace your dryer rather than repair it since its past 10 years old.
Old October 25th, 2009, 10:29 AM
Any idea what the capacity is?
Old October 25th, 2009, 10:43 AM
Nope, no idea, like I said above all are basically the same capacity, except for the compact miniature dryers.
Old October 25th, 2009, 11:05 AM
Kemmore has a 5.3 cu. ft dryer and a 7.0 cu. ft. dryer with the only difference in their external measurements being the larger capacity one is an inch deeper. 43 3/8 x 29 v 28 vs. 43 3/8 x 29 x 26) The dryer I've got is 43 3/8 x 29 x 25 1/2. FWIW, not sure how the manufacturers calculate capacity but I measured the inside of the drum (25" diameter, 18" deep) and it works out to about 5.1 ft. So I guess the smaller one would work for me.
Thanks...
Old October 25th, 2009, 12:59 PM
Yes, I checked the sears site and I didn't see the 5.3. It started at 3.9 and then jumped to 5.7 and up.
The most common size is the 7.0.
They never used to measure dryer capacity by cu.ft.
But since the front-loaders washers came out about 10 years ago, seems all washers and dryers now have a cu.ft. measurement.
Old October 28th, 2009, 05:13 PM
My mistake, No 5.3, I meant 5.7. Anyway, I see the power cord for dryers is sold seperately. Is it possible or even advisable to use the power cord from the current dryer for the new one?
Kenmore Elite Electric Dryer Problems - A Nudge in the Right Direction mcannon Sears Kenmore 5 October 9th, 2009 08:14 PM
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 28th, 2008 10:46 PM
Kenmore electric dryer does not heat. fiabeg Sears Kenmore 3 June 3rd, 2008 08:22 PM
Kenmore Elite Dryer 110.60092991 - Constant Beeping rbusch Sears Kenmore 7 October 21st, 2007 11:59 PM
Kenmore 90 Series Gas Dryer Problem HomeRepairGreenhorn Sears Kenmore 9 March 15th, 2005 01:02 PM
