Old November 1st, 2009, 04:06 PM
stusteiner is on a distinguished road
Default [FIXED] Kenmore HE2 Washer
I have a Kenmore HE2 Washer model 110.46462501 without a display. I ran the diagnostic test and I think I have an F/21 error -- add a garment rinse clothes clean.
Most like a pump filter problem I am betting? How do I clean the pump filter? Do I have to tip the washer back to remove the bottom panel?
Any information would be greatly appreciated
Stu
Old November 1st, 2009, 10:18 PM
Hi Stu,
Yes, you can tilt your washer back a little to get better access to the 3 bottom screws to remove the lower access panel.
Unplug the Machine
Remove Three Torx (hex heads) screws on front bottom of machine. Slighty lift the panel and pull the bottom towards you. Pump is right in middle in front of you.
Unscrew the pump handle with your hand, get something to catch the water thats left in it in.
The water pump changes from #8540024 to #W10130913:
(The manufacturer has replaced part#8540024 with this item, part #W10130913.) (Manufacturer part#W10130913 is RepairClinic item #1373005.):
Let me know what you find.
Old November 2nd, 2009, 07:31 AM
Default Clean and Working
Thanks for the information. I got it cleaned out. It was pretty full of lint and whatever. Some of the more interesting stuff
a pencil tip with the eraser
a broken key
6 bobby pins
50 cents 1 quarter 2 dimes 5 pennies
3 hair ties
a small rock
Ran a couple of loads after it was cleaned, no problems.
Old November 2nd, 2009, 09:22 AM
Excellent Stu, sounds like you got it.
Tags
101.46462501, he2, kenmore
[FIXED] Kenmore HE2 Washer - water not coming in aa95 Sears Kenmore 5 June 9th, 2009 08:13 PM
Kenmore HE2 washer stop and will not start again? spectorequipment Sears Kenmore 3 September 13th, 2008 08:43 AM
Kenmore HE2 Washer - Noisy when draining sdmoline Sears Kenmore 7 August 30th, 2007 02:55 PM
[FIXED] Kenmore HE2 Washer INOP hojo Sears Kenmore 9 June 21st, 2007 10:33 AM
Kenmore washer intermittent burning smell mvmartin Sears Kenmore 1 February 10th, 2006 12:40 AM
