Old November 26th, 2009, 01:15 PM
rte cat is on a distinguished road
Default [FIXED] Need Help with Elite HE3 Dryer no heat
I have the Elite electric dryer mod # 110.82822102 and it runs but no heat. the dryer vent goes down in the crawl space then over about
12 ft then up about 4 ft and vents outside. I try and keep it cleaned out.
It will overheat if I don't keep it cleaned out. When it overheats it shut off. you can let it set for about 30 min and it starts up. Now it runs but does not heat up and the vent is clean. I have taken the front off several times and cleaned all the lint out. This morning I took the lower front panel off and it was packed full of lint, I mean packed full and tight.
I cleaned it out but still does not heat. What do I need to start checking?
I do have an ohm meter.
There is no way of making the vent any shorter or more direct.
Vance
Old November 26th, 2009, 02:01 PM
Its likely going to be either the heater itself or the thermal cut-off thats mounted on the side of the heater housing.
Check those for continuity with your ohm meter with the wires removed from those 2 first, make sure you unplug your dryer first.
You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #32 screws, and you also have a screw at the very bottom of the duct assembly with a bracket#11 attached to it, remove that one also.
Your thermal cut-off#47 here, heater #14 here:
http://c.searspartsdirect.com/lis_pn...1247-00003.png
Here's the thermal cut-off#47 for your model:
Manufacturer part#279973 is RepairClinic item#897710
279973
Here's the heating element#14:
Manufacturer part#3387747 is RepairClinic item#525502
Old November 30th, 2009, 04:57 AM
It was the heating element.
replaced it, cleaned all the lint out,
working great.
Thank you,
Vance
Old November 30th, 2009, 11:30 AM
Excellent Vance, good job.
Kenmore Dryer 417.94072301 No Heat brimmyhop Sears Kenmore 1 September 28th, 2008 10:46 PM
Kenmore Elite HE3 Gas Dryer No Heat billjes Sears Kenmore 1 June 26th, 2007 08:27 AM
Kenmore Elite Ser. 70 Dryer 110.67612690... Timer Stops and no heat BaerEssentials Sears Kenmore 1 December 26th, 2006 09:40 PM
Kenmore Elite electric dryer no heat... route62 Sears Kenmore 4 January 10th, 2006 02:40 PM
Heat is intermittent on Kenmore Elite Dryer (model 110.60092991) mikefromottawa Sears Kenmore 8 June 14th, 2005 06:05 AM
