December 17th, 2009, 01:29 AM
Kenmore washing machine not spinning
Hello,
I have a Kenmore, top load, direct drive washing machine that has stopped spinning while in the spin cycle. It is also making a rumbling, clicking sound during the spin cycle.
I have removed the motor to see if it was the coupler that was broken but the three pieces are fine. I am now guessing it is the drive block since I can spin the basket with my hands. However, I can't seem to remove the spanner nut since the basket spins as I try to unscrew it. I am guessing that it is not supposed to do that.
Any suggestions? Would the fact that the basket is spinning as I try to unscrew the nut suggest other problems?
December 17th, 2009, 04:13 AM
December 17th, 2009, 10:06 AM
Whats the model# of your washer? Its located inside the lid.
Are you turning the spanner nut clockwise? On these models its reversed thread to loosen that nut.
December 17th, 2009, 11:31 AM
Yes, the water is drained, it just does not spins.
The model number is 110.24964300. I haven't tried to turned it clockwise so I'll see if that does the trick.
December 17th, 2009, 04:11 PM
Ok thanks, let us know how it goes.
Yes, Sounds like your tub drive hub is stripped.
Here's the tub drive block for your model:
Manufacturer part number 389140 is RepairClinic item number 2858
389140
By kdierk in forum Sears Kenmore
Last Post: October 17th, 2011, 11:43 AM
By danhustonii in forum Sears Kenmore
Last Post: November 26th, 2010, 01:34 PM
Last Post: November 6th, 2009, 09:27 AM
By ccadwellx in forum Sears Kenmore Reviews
Last Post: February 7th, 2006, 06:22 PM
By jhelton007 in forum Sears Kenmore
Last Post: July 22nd, 2005, 05:09 AM
Tags for this Thread
