February 19th, 2010, 03:23 PM
Kenmore 59652672200 fails again after changing start relay
Hello,
This is my situation: my Kenmore 596.52672200 stopped cooling after 7 years of service.
You could hear the compressor click-hum every few seconds. So after reading the posts here I changed the start relay and capacitor, after I cleaned the dirty bottom coils.
that done it worked for 3 days, and you could hear a more faint click hum every once in a while but it worked.
Does this mean that the compressor is dead this time?
Would a hard start kit work for longer?( if so any help on chosing one is appreciated).
The resistance on the compressor three connectors was tested. I got 8.8 ohms on one side and 4.3 & 4.2 on the others. which add up! (sort off)
I also checked that the fans are running inside and outside of the fridge.
Any help is appreciated.
Ted
February 19th, 2010, 04:57 PM
Edit
I forgot to clearly mention that the fridge stopped cooling again.
February 19th, 2010, 11:14 PM
Hi Ted,
Yes, its your compressor thats shot. No, a hard start kit wouldn't do any good.
It would cost about $400-$500 to have a new compressor installed. So with the age of it, it would be advisable to buy a new refrigerator.
February 20th, 2010, 07:16 AM
Thank you
Thank you for your reply. That's what I thought. i checked for a new compressor. the cost is about 300 dollars. i'll try to find a tech of craigslist to see if they can swap it for cheap.
This is a 1000$ + fridge. I would hate to waste it. such a shame that it died so fast.
Thank you very much.
February 20th, 2010, 09:45 AM
I'd be careful hiring someone from Craigslist, changing a compressor can only be done correctly by a highly skilled licensed refrigerant tech.
Hate to see you get ripped off $200-$300 for labor if something goes wrong and the craigslist guy disappears after hes done installing it.
February 20th, 2010, 05:03 PM
hard start kit
Well, I don't encourage the use of these BUT, your ohm readings sound as though the winding resistance is within normal operating specs. You could probably get away with using one, but I'd be shopping. The hard start just gives the compressor a boost upon start up. I personally will only place one on IF the customer has a refrigerator they are planning on repairing, and only to get them through for a week or so. They are ONLY a band-aid for an imminent catastrophic failure. Best of luck.
As for Jake's advice about craig's list. Do not buy an appliance there. I have many horror stories from my customers in the field. In fact, just yesterday I had a customer buy a laundry center for $75 and the dryer wouldn't heat. The gas valve was failed and the part cost $173. Obviously, they were unhappy.
The Following User Says Thank You to jmshaffer For This Useful Post:
May 9th, 2010, 11:22 AM
May 9th, 2010, 01:09 PM
Yes, if the hard start kit makes it work for awhile thats fine.
But if you wake up one morning and its warm in your refrigerator, you will know its over, but hope you have a job when that happens.
Last Post: October 20th, 2011, 10:46 AM
By brgr in forum Sears Kenmore
Last Post: December 26th, 2009, 11:26 AM
By KevinP in forum Sears Kenmore
Last Post: September 23rd, 2009, 08:41 AM
By allanr in forum Sears Kenmore
Last Post: September 7th, 2009, 07:25 AM
By cefox01 in forum Sears Kenmore
Last Post: April 16th, 2006, 02:53 PM
Tags for this Thread
