March 2nd, 2010, 08:53 AM
[FIXED] Kenmore Dryer 417 88052700 Runs but no heat need a diagram to take a look.
Had great luck with this forum last time for my oven now Im back for my dryer.
It runs fine, drum turns, but there is no heat. I shook it a little when it was running and the heat elements flicked on briefly, so Im guessing theres something loose.
Looking for a diagram so I can get in there and look at it. Looks like I have to take the drum out???
Can some one help please!
March 2nd, 2010, 09:05 PM
Hi, welcome back.
You will need to unplug or turn the breaker off to your dryer, then take it apart, this link will show you how:
White-West, Frigidaire repair info, how does the dryer come apart, front flides and how to replace them
Then look at your element, you may see a broken element wire.
If a broken heating element wire isn't obvious, You would need a volt/ohm meter to diagnose it:
Frigidaire, White Westinghouse, Magic Chef, Maytag Performa Dryers, common repair info, no heat, noises, how to take apart
Here's the heating element assembly for your model:
Manufacturer's Number: 131553900
Here's also the repair manual for your model you can print out the sections you need to:
http://www.applianceblog.com/manuals...Dryer_2005.pdf
March 5th, 2010, 05:24 PM
Kenmore dryer
Hey Jake. Thanks for the info. I took the dryer apart and saw that the heating element was broken in half. So I ordered a new element (just the "spring" like part not a new "pan" around it) and installed it.
Put the dryer back together, plugged it in and it came on. Pressed start and it spins about once then flips the breaker in my fuse box.
Unhooked the element connection and the dryer spins fine and the breaker doesn't flip.
Not sure what Im doing wrong. Can you advise?
KL
March 5th, 2010, 06:13 PM
Ok KL,
Your element wire must be touching the pan, thats why I never just order the element wire, I hate stringing that wire all around the pan.
March 6th, 2010, 11:23 AM
Working!
Got it working. Thanks!!!
March 6th, 2010, 02:32 PM
Excellent, good job.
March 17th, 2010, 12:19 PM
Fixed Element now I have another problem
Theres an annoying click/thump now. I took everything apart again and put everything back together. Made sure everything was screwed in tight, and that the drum wasnt hitting something inside. The thump seems to occur when one of seems on the drum goes by a certain spot in the dryer but I cannot find anything. It does it sometimes then other times it doesnt.
Any thoughts?
March 17th, 2010, 10:00 PM
Not sure what is causing it, you may need to take the drum out again and see if you can locate what's doing it.
January 24th, 2012, 12:11 PM
I have this same problem where the drum turns and the heat does NOT come on. I tried to open the manual above, but it would not open. I need help determining the problem, the dis-assembly and re-assembly of the dryer. Help!
January 24th, 2012, 02:57 PM
We need the model# of yours:
Help Me Find My Model Number - RepairClinic.com
That manual opened fine for me.
Last Post: September 28th, 2008, 10:46 PM
By fiabeg in forum Sears Kenmore
Last Post: June 3rd, 2008, 08:22 PM
By shoemakermj in forum Sears Kenmore
Last Post: April 18th, 2007, 07:58 AM
By SF_Sam in forum Sears Kenmore
Last Post: July 13th, 2005, 11:03 AM
By mikek in forum Sears Kenmore
Last Post: May 4th, 2005, 06:48 AM
