Sounds like 2 problems you have.
For the not cleaning issue:
I'd check the chopper screen blade assembly first.
https://secured.whirlpool.com/Servic...LE/8178022.pdf
Page 17 Read 1-4 where it says this:
Lower Spray Arm
It shows how to get access to the chopper screen.
Chopper Part#8268383
If those check ok, then its possibly your motor assembly thats bad.http://www.repairclinic.com/referral.asp?R=1265&N=1018625
(Circulation pump motor with volute, shaft seal and impeller)
For the Not drying good issue:
Sounds like a bad heating element.
On this model the heating element comes with a new control board.
Here it is:
Manufacturer part number 8194200 is RepairClinic item number 1094552
You would need an ohm meter to test for continuity on it, normal would be 11-50 ohms.
Make sure you turn the breaker off to your dishwasher first.
The heating element terminals are in the back, so you would need to pull the dishwasher out to get to them.
Let me know what you find.
LinkBack URL
About LinkBacks
