Old November 10th, 2005, 12:53 AM
Daytona313 is on a distinguished road
Default Kenmore Oven shuts itself off / locks door
My Kenmore oven model number 790.93762000 serial number VF00738855 with back panel number 316123617 will shut itself off soon after it reaches the set temperature and the door lock opens and closes the door right before the oven shuts itself off. Any help would be appreciated.
Thanks, Dale
Old November 10th, 2005, 04:33 AM
Lights/display goes off and resets to the clock/time?
I have had a couple of Frigidaires ( they built your Kenmore ) do something similier....door lock kept setting and unsetting....but on most of mine the oven would not work from the get go.
2 of 3 needed new clock, 1 of 3 needed clock and lock ( figured the lock was damaged from running soo much )
Oven temp sensor -normally- ohm at approx 1000-1100 ohm at room temp.
Electronic control - still need seperate coloured sticker on front!
Motor-lock assembly
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old November 10th, 2005, 02:21 PM
Motor-lock assembly
When the problem starts the light switches from "oven" to "lock" and it blinks while the door opens and closes and then shuts itself off . Do you think I just need a new electronic clock control or do I need a oven temp sensor as well?
Thanks for the help!!
Kenmore model 790.9661* oven door problem hammesd Sears Kenmore 13 October 26th, 2008 09:18 AM
Kenmore Elite Oven Door Glass Shattered Jimbo3322 Sears Kenmore 4 October 2nd, 2007 11:46 PM
Kenmore washer won't run without pressing on door Dee341 Sears Kenmore 5 April 24th, 2007 03:34 PM
Broken glass on Kenmore oven door mandapanda Sears Kenmore 2 September 25th, 2006 05:06 PM
Kenmore Elite HE3 door locks twice during cycle? smiley26 Sears Kenmore 3 January 13th, 2006 06:43 AM
