June 12th, 2010, 09:45 AM
[FIXED] Kenmore Ultra Wash Quiet Guard 3 - not heating water?
Seems like the dishwasher is not heating the water? It isn't drying with heat either I believe...I am wondering if there is a blown heating element I can replace myself without a repair man?
June 12th, 2010, 10:25 PM
Yes, sounds like the heating element is bad. You can ohm it, it should read 11-50 ohms. Make sure you turn the breaker off first to the dishwasher before doing the ohm test.
The Sears site is down tonight for maintenance, I'll get the part# in the morning.
June 13th, 2010, 08:31 AM
Will I need additional parts supporting the repair or just the element itself? Hard to replace?
Your expertise is much appreciated!
June 13th, 2010, 11:12 AM
No, you shouldn't need additional parts.
Here's the heating element for your model you can order:
Manufacturer part#W10134009 is RepairClinic item#1381534
Yes, there is 2 ways you can do it, you can either unhook your plumbing, electrical, and drain hose from it and pull your dishwasher out to get to the back of it,
or take off the front panel as described on page #17, step#1, Fig.3-7:
https://secured.whirlpool.com/Servic...LE/8178022.pdf
then remove the access panel described on page #20, step #1, Fig.3-15.
then remove your drain pump described on page #21, step #1 & #2, Fig3-18.
Then follow my thread post #2 here:
Sears Model 1650920 Dishwasher
June 14th, 2010, 03:19 AM
Thank you very much! I wil update you!
June 14th, 2010, 08:23 AM
Whirlpool Manual
Jake - just one more question...your references are to a Whirlpool dishwaser manual...same make and modeal as the Kenmore ?
June 14th, 2010, 08:30 AM
yes this kenmore is made by whirlpool
June 14th, 2010, 04:23 PM
Part ordered...I'll keep you updated! Appreciate all the help very much!
June 14th, 2010, 11:36 PM
June 20th, 2010, 09:45 AM
Just wanted to follow up with you.....part came in Friday and installed it yesterday and I have nice clean dishes!!!! I can't thank you enough for your help...this cost me less than $30 and I figure I saved over $200 by the time I would have had a repair man out.
Thanks...wish I could return the favor. I really appreciate it very much!
By Ross in forum Sears Kenmore
Last Post: October 3rd, 2009, 09:59 PM
By amber in forum Sears Kenmore
Last Post: January 15th, 2009, 11:44 PM
By Jewel in forum Sears Kenmore
Last Post: August 31st, 2007, 11:22 AM
By verusfemina in forum Sears Kenmore
Last Post: October 22nd, 2005, 09:52 PM
