Results 1 to 4 of 4
Thread: Kenmore Tuble Action Washer Drum Busts Loose!
    oregonloos is offline Premium Member
    Mar 2007
    Tigard,Oregon
    Exclamation Kenmore Tuble Action Washer Drum Busts Loose!
    Model Number: 417.40042990
    I have a Sears Kenmore Tumble Action Washer (Front Loader)
    Which produced a loud thump/snapping, and then made the most awful screeching grinding sound in the final portion of the spin cycle "fast".
    Really, it sounded like an airplane was going to crash into our house.
    Stopping the machine and feeling the drum it seems as if it is no longer as anchored as it was. It still feels suspended, but I can easily move the drum back and forth, whereas before it was flexible, but there wasn't as much play.
    Is it time for a new washer, or is this something I can fix? Any help greatly appreciated, as I have a 13month old whose laundry reproduces quickly!
    Thanks Much,
    Angela
    Model 417.40042990
    Serial XC03106592
    Manf 7/2000
    Hi Angela,
    Yes, its time to retire your washer. Your tub bearing and inner tub spider arms sounds like they have broken.
    If you are looking for a challenge and have lots of time on your hands, here is a guide to fix it:
    http://www.applianceblog.com/mainfor...-bearings.html
    But with a 13 month old, I'd say go to Sears tomorrow and get a new washer.
    Mar 2007
    Tigard,Oregon
    Default But I Love my Washer...
    I did fix this machine once with your gifted help.. but alas, I also work full-time. I saw those instructions. I think it would take me way more than 3 hours..
    Say, Just to be sure I represented the problem correctly:
    When turned by hand, drum sounds fine. No clunking or sounds like the spider arm is clunking around, but I guess if it just cracked it wouldn't.
    Fills and empties fine, however, when it spins, it starts to knock. On gentle cycle, it sounds like a fast horse trot, on regular cycle, it sounds much worse than that, but not constant. It's in the transition(s) from speed to speed where it knocks.. as if, once it finds a good place, it's fine. Is the knocking from the inner drum hitting the outer drum?
    I could be in denial, especially since this unit is stacked, Dryer is fine and I have no idea what to replace it with. Is it worth having someone look at it?
    I Just can't believe it's over .
    Thanks Again Jake. You Rock.
    Yes, did you check your 2 shock absorbers under the outer tub assembly to make sure they didn't break?
    If the shocks are fine, then its all the bearing and inner tub spider supports.
    Oh yours is stacked? You could go to Sears and see if they have a new washer that will be identical to yours so you can keep the dryer stacked on the new washer.
  1. FIXED: Sears Kenmore Tumble Action Washer 417.44102 - Loud Noise
    By selvasol in forum Sears Kenmore
    Last Post: January 28th, 2012, 04:45 PM
  2. Kenmore washer
    By AlanS in forum Sears Kenmore
    Last Post: September 8th, 2010, 09:18 PM
  3. Replies: 3
    Last Post: June 29th, 2010, 03:19 PM
  4. Kenmore Tumble Action Washer WON"T DRAIN
    By dirtylaundry in forum Sears Kenmore
    Last Post: March 12th, 2007, 07:43 PM
  5. Kenmore 80 Series Model 110 Washer - Tub loose??
    By mengle in forum Sears Kenmore
    Last Post: January 28th, 2006, 11:32 PM
Tags for this Thread
