Results 1 to 2 of 2
Thread: Kenmore dishwasher will not drain
    ram435 is offline Member
    Dec 2010
    Default Kenmore dishwasher will not drain
    Model Number: 665.13723
    My dishwasher stopped draining last night. There was a 2 inch layer of dirty water at the bottom this morning, but the dishes were clean. It is 4 years old, and this is the first time it has faulted.
    I checked the drain hose where it connects to the drainage under the sink. Not even a drop came out when I unhooked it. There was no obstruction or clogging. I then checked the drainage hose right upto where it connects to the dishwasher, and it appears clean. Then I unhooked the hose from where it connects to the dishwasher, and water came gushing out. However, I did not find anything obstructing in the L shaped red connector or the hose.
    Looks to me like a motor problem? Does this dishwasher have a different motor for drainage? Where should I look next?
    Thanks in advance.
    Raminder
    Ok first try to manually drain the water, push the drain/cancel button and notice if any thing happens, any sounds at all? Humming?
    You have a separate drain motor on this model.
    If you hear a humming sound and its not draining that usually means either something is jammed in your drain motor impeller, or your drain motor bearing is locked-up.
    Page 21 here shows you how to take apart the drain motor:
    http://www.applianceblog.com/manuals...voy8178022.pdf
  1. Another Whirlpool Dishwasher won't drain
    By rickm in forum Whirlpool
    Last Post: October 3rd, 2011, 04:14 PM
  2. Replies: 4
    Last Post: September 30th, 2010, 01:25 AM
  3. Kenmore Dishwasher won't drain
    By parrotheadlois in forum Sears Kenmore
    Last Post: December 20th, 2006, 12:12 PM
  4. Help My Kenmore Dishwasher won't Drain
    By lacrue79 in forum Sears Kenmore
    Last Post: August 4th, 2006, 06:34 PM
  5. Kenmore dishwasher 665.15929001 won't drain
    By distressed_kenmore_user in forum Sears Kenmore
    Last Post: September 5th, 2005, 10:19 AM
