Results 1 to 6 of 6
Thread: Dryer won't stop on timed dry or auto dry
    rhino1975 is offline Member
    Jan 2011
    Bedford, TX
    Question Dryer won't stop on timed dry or auto dry
    Model Number: 110.72602101
    Our dryer doesn't stop in timed dry or auto dry. I can hear the timer clicking. Is it time for a new timer?
    Ok first do this: when the dryer is running open the door, then wait till it stops, then close the door, if your dryer starts by-itself WITHOUT you pushing the push-to-start button, then its definitely your push-to-start switch thats bad.
    Here's the push-to-start switch for your model you can order:
    Manufacturer's Number: 3977456
    3977456
    If thats not the case, then yes, you would need a new timer.
    Here's the timer for your model you can order:
    Manufacturer's Number: 3977678
    We have a special return policy, if you install the timer and it doesn't fix your dryer, you can return it within 45 days for a full refund.
    Jan 2011
    Bedford, TX
    Thanks! When I open the door and then close it, it does not start by itself. I'll order a new timer.
    Ok, yes, keep us posted.
    Jan 2011
    Bedford, TX
    We decided given the age of the dryer we don't want to put in $110 to replace the timer. We'll just use the kitchen timer. Thanks for your help diagnosing it though!
    Ok, sounds good.
  1. Kenmore Dryer 417.94072301 No Heat
    Last Post: September 28th, 2008, 11:46 PM
  2. Whirlpool dryer LER 7646 AN1 stops in middle of dry auto cycle
    By imidazol97 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 31st, 2008, 11:07 AM
  3. GE dryer fails to stop in auto mode
    By wddanie in forum GE/Hotpoint
    Last Post: November 29th, 2007, 05:14 PM
  4. Maytag MDG3706AWW auto dry/auto dry wrinkle won't stop
    By pherbolario in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 6th, 2007, 04:45 PM
  5. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    Last Post: August 19th, 2005, 09:48 PM
