Old December 16th, 2005, 09:45 PM
tjs tjs is offline
tjs is on a distinguished road
Default Kenmore keeps blowing thermal fuse. HELP!
Kenmore model# 110.86574810. Here is the sequence of events-
1) Dryer quit, tested thermal fuse, fuse bad, replaced.
2) Dryer quit again after about 3 loads, tested fuse, fuse bad. Replaced fuse along with new aluminum external duct, new wall vent and all.
3) Dryer quit again after 3 loads, roomate said clothes were hotter than **** when removed from dryer, tested fuse, fuse bad. Checked blower fan, spins free. A small amount of debris at bottom of internal duct, not enough to restrict. Took a leaf blower and blew out internal duct. There is NO lint in internal or external ducts, ZILCH.
Before I waste another $12.00 on another thermal fuse, how do I test the operating t-stat, heating element, and hi-limit t-stat on element housing? Or should I just replace them all? I believe the above parts are original. I want to make ONE more trip to the appliance parts store...
HEEEEEEEEEEEEEEELP!!!!!!!!!!!!!!!!!!!!
Old December 17th, 2005, 03:58 AM
Check for a shorted to ground heating element. Check air temps at the dryers exit, it should cycle approx between 120 degrees and 160 degrees....let us know what you find/see.
Heating element with wires
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old December 18th, 2005, 08:30 PM
tjs tjs is offline
I tested the element, it is not shorted. (With power disconnected, I checked for continuity to element cage, there is none.) Coils are intact, none broken. I have not checked the temp of the exaust air, it's the weekend and I cannot get a new fuse and other needed part until tomorrow.
Soooooooo, should I get a new cycling thermostat along with a fuse? I'll check the air temp after a new fuse, but I want a new t-stat on hand also, what else could it be?
Much thanks for the help!!!!!!!!!!!!!!
Old December 19th, 2005, 04:09 AM
tjs tjs is offline
One more thing-
Took the cycling t-stat out to bring it to the store when I go there at lunchtime. I can shake it and I hear a rattle inside of it. Does that mean the bi-metal spring inside is broken??
Old December 19th, 2005, 04:20 AM
Doing something wrong in the testing procedure!??!
Nope. Roundish spring plate inside oftne rattles, the plate flexes to open and or close the contacts.
JRAppliance
Old December 19th, 2005, 05:12 AM
tjs tjs is offline
Element needs power to test?????
Old December 19th, 2005, 02:34 PM
flexjay is on a distinguished road
i would unhook vent and run dryer for a few loads and see what happens. make sure you have real good air comin out .(blower wheels can break , but still spin freely, too freely) after that i would get a vom meter and a temp. meter and check exit temp. (per spec) and check to see if t-stats are opening up to shut off heat as needed.
Old December 20th, 2005, 04:16 AM
If no continuity is found across the element, it is considered open or bad....but with no breaks or such, the element should show continuity.
If all else checks ok, replace the operating thermostat and thermal fuse and test the air temps ( heat on and off ) at the dryers exit.
JRAppliance
thermal fuse keeps blowing chanchamone KitchenAid 2 July 9th, 2007 08:55 AM
Sears Kenmore Thermal Fuse Blowing herrgomes Sears Kenmore 5 February 11th, 2007 11:04 PM
Kenmore 70 Series - Thermal Fuse ? BeccaSue Sears Kenmore 7 September 12th, 2006 09:57 PM
Kenmore 70 Series - Thermal Fuse Keeps Blowing Out rebepany Sears Kenmore 5 March 16th, 2006 05:56 PM
Kenmore 70 series thermal fuse kimmyvb10 Sears Kenmore 3 September 15th, 2005 04:09 AM
