Results 1 to 9 of 9
Thread: Compressor has trouble starting
    Andy54 is offline Member
    Feb 2011
    Connecticut
    Default Compressor has trouble starting
    Model Number: 106.7698380
    The compressor on this old fridge usually starts fine, but sometimes it doesn't start ... instead it hums for a few seconds, and then the protection circuit shuts it down ... it tries again in a few minutes, and it usually starts ok then. It always starts eventually, and the cooling is fine. Questions:
    1. Should I replace the compressor start device? Or does a compressor start device "fail completely when it fails" (and, as I said, the compressor usually starts fine).
    2. Is there a separate starting capacitor on this model, and should I test/replace this? Is there also a separate running capacitor (which I assume would not affect starting)? If there are two, how do I tell the two capacitors apart?
    Thanks.
    This is a 1979 refrigerator, so it sounds more like your compressor is just wearing out and thus this issue your having, I doubt a new compressor start relay will solve this.
    Maybe its time to retire this refrigerator, its had a longer than normal life.
    And the new refrigerators of today have a much more energy efficient compressor and you will definitely notice your electric bill decrease a lot.
    Feb 2011
    Connecticut
    Thanks for your quick reply and your complements to this long-lived fridge.
    However, I still want to "keep it on the road" if possible. It's in a summer cabin that's owned by an elderly friend, and it's only used in summer months.
    Are you saying that a new compr start relay will probably not solve the starting difficulty, because start relays "either work or fail completely"? And what about the capacitors ... is that something to go after?
    Thanks.
    Andy
    Exactly Andy.
    No, because the capacitors used on refrigerators are for the running of the compressor, after it starts.
    Feb 2011
    Connecticut
    OK. Thanks for the reply. I guess I'll have to replace the fridge.
    Andy
    Ok Andy.
    Feb 2011
    Connecticut
    Default Compressor has trouble starting -- now symptoms have changed
    Hi Jake,
    I'm writing again about the same fridge (1979 Kenmore Model 106.7698380). I have not replaced it since we last communicated about it 18 months ago.
    But the symptoms have transmogrified. When the thermostat calls for it to start, it starts fine in about half of the instances ... this part is the same as before. What's different is that, when it doesn't start right, something buzzes very loudly ... you can hear it throughout the house ... sounds like a buzzing relay ... it buzzes for about three seconds, then it turns off (which I assume is due to the thermal overload protector), and a few minutes later it tries again and usually starts fine on the second attempt. There has never been any problem with insufficient cooling, i.e. the compressor always does start by the second or third attempt.
    When I wrote 18 months ago, the noise was just humming, as if the compressor failed to turn over. Now, instead of the humming, there is this loud buzzing ...
    Does this affect the diagnosis?
    I'm wondering about the start relay, PTC relay, capacitor? Is it worth trying replacements of any of these parts? If not too much trouble, what are the p/n's I need?
    BTW, before I disassemble anything and possibly cause it to fail altogether, I want to have the replacement parts on-hand!
    (And please help me out with basic understanding: Are the start relay and PTC relay the same item with two names? And is the thermal overload protector inside the sealed compressor unit, or is it also external?)
    Thanks.
    Andy
    Its still the compressor Andy.
    Go refrigerator shopping this weekend.
    Feb 2011
    Connecticut
    Thanks Jake.
  1. Bryant Furnace Starting Problem
    By bryant80 in forum HVAC
    Last Post: March 26th, 2011, 11:23 AM
  2. Washer has trouble starting
    By BILBO in forum Frigidaire/Electrolux
    Last Post: September 12th, 2010, 07:59 PM
  3. [FIXED] GE Profile - PDW7300J03WW not starting
    By Wrog in forum GE/Hotpoint
    Last Post: September 24th, 2009, 10:10 PM
  4. Most trouble free high quality french door refrigerator?
    By ron in sc in forum General Appliance Chat
    Last Post: December 21st, 2008, 08:47 PM
  5. Dishwasher trouble
    By waldreps in forum KitchenAid
    Last Post: February 27th, 2007, 10:10 PM
