Results 1 to 9 of 9
Thread: Kenmore model 596.72253200 problem
    Derekkeach is offline Member
    Apr 2011
    RI
    Default Kenmore model 596.72253200 problem
    Model Number: 596.72253200
    I have a Kenmore model 596.72253200 and it started to make a click sound along with buzzing noise then click and stop for a few minutes. The temp in the freezer and refrigerator are worm almost room temp and the compresor is very warm to hot. Does anyone know what could course this and the solution.
    quik-fixit is offline Premium Member
    Mar 2011
    tidewater
    The Amana proverbial failed start relay, the compressor has started a long lingering death......you can start with replacing the start package, P/N 67005560, that should fix it for a while............ If not, a 3-N-1 RCO810 to get you thru till you find a replacement .............mine has lasted more than a year on the same replacement P/N 67005560 ..........When it goes I will replace the compressor...........good model of refer.........
    Apr 2011
    RI
    i checked the overload relay and capacitor they were both good. does this mean my compressor needs to be replaced.
    Yes, its the compressor thats bad.
    Check your warranty in your owners manual, some have up to a 10 year warranty on the compressor, you would just have to pay labor to have it installed by Sears.
    Apr 2011
    RI
    Unhappy
    only have 10 year warranty on ones sold in Canada.
    Apr 2011
    RI
    I took the overload apart and then put is back together, reinstalled it. when I plugged the refrigerator back in the compressor turned no and it started to cool.
    Oh really? So its cooling now today as well?
    If so thats great.
    Apr 2011
    RI
    yes it is still working good.
    Sounds good then.
  1. [FIXED] KENMORE 970-C47072-00 PROBLEM - Help!!
    By Rad_Rick in forum Sears Kenmore
    Last Post: January 24th, 2010, 10:23 AM
  2. Replies: 1
    Last Post: December 28th, 2008, 06:04 PM
  3. Replies: 2
    Last Post: December 3rd, 2006, 01:03 AM
  4. Kenmore Elite Model 110.61082000 Problem!!!
    By Just Julie in forum Sears Kenmore
    Last Post: April 8th, 2006, 05:37 PM
  5. Kenmore Series 80 model # 110.28882790 problem
    By Zenitramocir in forum Sears Kenmore
    Last Post: December 30th, 2005, 01:30 AM
