Results 1 to 4 of 4
Thread: HE3T stopped mid cycle.
    nesbandit is offline Member
    Apr 2011
    tallahassee fl
    Default HE3T stopped mid cycle.
    Model Number: 110.45976404
    My HE3T washer stopped mid cycle (14 min left). It had an error code of FH, I pressed and held cancel to reset it and the thing quit reacting. It just sits there acting like it is draining; you can hit different cycles and the minutes change but that is it. It will not shut down and the cancel button doesn’t work. Thanks in advance for any help you can give me.fficeffice" />>>
    quik-fixit is offline Premium Member
    Mar 2011
    tidewater
    Is there water in the unit and trying to drain?? press PAUSE/CANCEL twice to clear the display........FH= No water detected entering the machine........I would check the drain pump first for debris...
    Apr 2011
    tallahassee fl
    have tried pushing the pause/cancel button and it does nothing. There is no water in the washer though. It is just stuck on drain cycle and I need to figure out how to get it off.
    Unplug your machine for 5 minutes, then plug it in to see if it resets.
  1. washer stopped mid cycle
    By tnvolsluvr in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 12th, 2010, 01:09 AM
  2. [FIXED] Kenmore 417.42042100 stopped mid cycle
    By liamof in forum Sears Kenmore
    Last Post: January 6th, 2009, 10:02 PM
  3. kitchenaid kudm01tjbl0 stopped in mid cycle no power
    By drew carlino in forum KitchenAid
    Last Post: November 18th, 2007, 02:28 PM
  4. Maytag SDE305DAYW stopped mid cycle
    By glenamijacob in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 5th, 2007, 05:39 PM
  5. Stopped mid cycle.
    By Aerocook in forum Frigidaire/Electrolux
    Last Post: December 11th, 2006, 10:04 PM
