Results 1 to 6 of 6
Thread: [FIXED] Kenmore Series 90 - no heat again and again
    dragonball is offline Member
    May 2011
    atlant
    Default [FIXED] Kenmore Series 90 - no heat again and again
    Model Number: 110.69912990
    My dryer has no heat. Again. Here's the story.
    Fix #1) About 5 weeks ago I had no heat. We tested everything and found the heating coil was broken. Replaced heating coil. It worked!
    Fix #2) about 2 weeks ago, again no heat. tested the fuse, thermostat, heating coil with an ohm meter. Fuse had the open circuit, ordered that and replaced it. It worked!
    Now #3) so now again we have no heat. I again tested the three parts fuse, thermostat, heating coil with an ohm meter. This time both thermostat and heating coil were found to have an open circuit i.e. broken. I haven't re-fixed it again, so now my dryer is not working. I could replace the two broken parts and the dryer will probably work again, but for how long. Is there some underlying problem causing all of this? I'm looking for thoughts on how to move forward. Do not want to throw good money after bad.
    In all cases there was nothing that looked burned or horribly wrong. My suspicion is that there is something else causing these problems, something that is triggering these failures.
    in all cases between fix #1 and fix #2 and between #2 and #3 we used the dryer (about 4 loads/week) and everything worked well.
    The dryer, when it runs, runs well, quietly, efficiently. No funny sounds, smells, etc...
    One thought I had, when I ordered the replacement fuse (for fix #2) Sears sent me both the fuse and the thermostat. I replaced only the fuse since the thermostat appeared to be ok, based on the ohm meter reading. Were they trying to give me a hint?
    Any ideas? Any other tests that I can run to validate things or just go ahead and replace the fuse and thermostat?
    The reason it keeps blowing these parts out is you have a vent restriction where your dryer vents to the outside of your house thus overheating those parts and blowing them out.
    Have you pulled the dryer out from the wall and checked your vent hose and piping that goes to the outside of your house for lint clogs?
    May 2011
    atlant
    Default duct smushed
    Thanks Jake,
    No I have not pulled out the ducts. Will do. One thing I did notice was that the dryer duct it crushed a bit.
    The flexible duct got smushed when the dryer was pushed back against the wall. The constriction is about 1/2 the diameter of the duct turning the cross section from a circle into an oval.
    Sounds like that might be it? or would is there likely to be a lint ball in there too??
    Yup, your duct smushed would definitely cause the problem.
    But still clean the exhaust hose and piping to the outside of your house just to be on the safe side.
    May 2011
    atlant
    Default with a clean duct my dryer won't selfdestruct
    Thanks I think I will simply replace the duct itself it's a mess.
    Thanks again!
    Ok, sounds good.
Tags for this Thread
