Results 1 to 5 of 5
Thread: Kenmore Elite electric dryer no heat...
    route62 is offline Member
    Jan 2006
    Orlando Florida
    Default Kenmore Elite electric dryer no heat...
    I have a Kenmore Elite electric dryer that is about 3 years old. The model no. is 110.62982101
    Dryer operates and runs fine but there is no heat.
    I did a search on this board and went to the appliance aid site and did the checks specified there:
    house breakers good and on
    240V to dryer
    continuity check ok on:
    power cord
    thermal cutoff
    thermistat
    Thermal fuse
    thermistor
    heat element continuity ok, checked ohms also in spec, heat element is not broken grounding or otherwise
    Blower vent, screen, exhaust etc all clear and blows hard and clean
    I also put the washer in a diagnostic and all control switches checked out, timer also advances.
    The control board looks good with no signs of burns or water damage etc. There is no signs of loose wires, corrosion or otherwise anywhere in the dryer.
    I am at a loss at this point. Did I miss something? Before I call a tech to come out I figured I would check here to see if there is anything else.
    Thanks in advance for any help.
    Oct 2004
    240V to dryer
    power cord
    thermal cutoff
    thermistat
    Thermal fuse
    thermistor
    Heat relay, motor heat switch, selector switch, timer contacts....as a test only, join the 2 heavy wires together on the heat relay.
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Jan 2006
    Orlando Florida
    Thanks Jeff for the response. I did as suggested and the heater element did come on and glow red hot for just a little bit then shut down. I am assuming that it did this since it got too hot and the thermal protection kicked in and shut it off? I assume that this means the heat relay is bad and needs to be replaced?
    Oct 2004
    Either bad relay or no power from the board to operate the relay.
    If the dryer is apart or partly apart the poor/improper air flow could allow the safety to shut off the element.
    JRAppliance
    Jan 2006
    Orlando Florida
    Thanks Jeff it was the relay. I went to the parts store and the guy there said that this particular relay is problematic. He did not have a more stable alternative so I may be replacing this again in 3 years. For now the dryer works and family is happy.
  1. Kenmore Series 90 Electric Dryer No Heat ?!?
    By parttimerz in forum Sears Kenmore
    Last Post: December 30th, 2012, 12:14 AM
  2. Replies: 1
    Last Post: December 26th, 2006, 10:40 PM
  3. Even Heat Board Fried in Kenmore Elite 110.73942101
    By caliamara in forum Sears Kenmore
    Last Post: December 10th, 2006, 09:55 AM
  4. Kenmore Elite HE3 Gas Dryer Electric
    By billjes in forum Sears Kenmore
    Last Post: September 21st, 2006, 12:29 AM
  5. Heat is intermittent on Kenmore Elite Dryer (model 110.60092991)
    By mikefromottawa in forum Sears Kenmore
    Last Post: June 14th, 2005, 07:05 AM
