Results 1 to 9 of 9
Thread: How to remove the fine screen to clean?
    joehawk is offline Member
    Jan 2006
    oregon
    Default How to remove the fine screen to clean?
    I have a Kenmore dishwasher, model 66515979990. The fine screen in the bottom of the dishwasher has fine particles of sediment [not mud-like as described in another post]. I want to take it out to clean it since it is not cleaning as well as previously, however I cannot figure out how to remove it. I took off the lower arm, and can see the screen. I removed the plastic water intake tube, but nothing budges. I sure would appreciate some advice on how to proceed further.
    Jan 2006
    oregon
    Default Moderator please move to Kenmore dishwasher forum
    I apologize, I have posted my first post in the wrong section.
    Thanks, got it moved to this forum.
    Here's a link of the parts breakdown to get to it, lots of screws to remove:
    http://www.applianceaid.com/wp-dw-pumps.html#older
    Here's another link:
    http://www.applianceaid.com/dish.html
    Jan 2006
    oregon
    Default OK, got the screen clean but...
    Thank you Jake for the great links. However now I find it is not cleaning as well as it has previously say as recently as a month ago. I found no plugged holes in the arms. The screen actually became really clean when I ran a cycle with lots of vinegar and the soap, so I didn't take it apart. I am wondering if the pump is worn or something?? Any thoughts on that?
    Yea, It could be your pump is wearing out, i replace alot of these pump/motor assemblies every year:
    Dishwasher pump and motor assembly
    Or you can first try this product, it does a great job in cleaning the pump out:
    Dishwasher Cleaner
    Jan 2006
    oregon
    Default It sounds like the pump alright!
    Thank you for your help, Jake. I appreciate the site for the part. I may try the cleaner idea first. Thanks again.
    Glad to help Joehawk!
    Keep us posted if you can on the outcome.
    Jan 2006
    oregon
    Default OK so far
    I have been using the 'pots and pan' setting after cleaning the screen using a lot of vinegar for a cycle. It is cleaning well with the extended wash cycle, but you must be right Jake, that the pump is wearing out. I will let it go for awhile until that extended cycle is not sufficient and plan to attempt the pump assembly at that point. I am not sure how it will come out of the dishwasher and may look to buy a repair manual for it to get idea how things go in there. Joehawk
    Hi Joehawk, yes buying the repair manual is a good idea, I was looking for one for your model, but didn't see one. You can e-mail the RepairGuru to see if they have one for your model.
  1. Replies: 9
    Last Post: May 14th, 2011, 08:37 AM
  2. My Frigidaire wont clean
    By Welder in forum Frigidaire/Electrolux
    Last Post: June 1st, 2009, 11:30 PM
  3. KUDP more questions for clean light blinking
    By Gradstudent in forum KitchenAid
    Last Post: March 23rd, 2007, 10:10 PM
  4. Whirlpool GU1500XTKB0 did not clean
    By Tedd in forum Whirlpool Reviews
    Last Post: February 4th, 2007, 10:33 AM
  5. Replies: 2
    Last Post: August 19th, 2005, 09:27 PM
