January 17th, 2006, 08:25 AM
Frostless Sears Kenmore refrigerator leaking inside
My Sears refrigerator is about 5 years old, and just started leaking on the inside. Drips appear to come from a mechanism that connects the freezer compartment to the refrigerator compartment. I have vacuumed the coils in the front and back. The manual does not give alot more help on how to deal with this problem other than storing food in tightly covered containers and openning the door as few times as possible. Any ideas?
January 17th, 2006, 10:22 AM
Its likely your drain area for the defrost water to drain to the drip pan is frozen up.
Jeff has a web page that explains this more:
http://www.applianceaid.com/frig_leaking.html
You will probably need to remove the freezer back panel and clear the ice blockage and run something through the drain, like a small drain rotor snake.
September 4th, 2009, 08:31 AM
By kgollnick in forum Sears Kenmore
Last Post: May 14th, 2011, 07:37 AM
By Lewandowskiifrank in forum Sears Kenmore
Last Post: December 21st, 2007, 04:00 PM
By ssrobzoom in forum Sears Kenmore
Last Post: June 11th, 2007, 10:18 AM
By millervt in forum Sears Kenmore
Last Post: May 24th, 2007, 08:47 AM
By djs239 in forum Sears Kenmore
Last Post: July 10th, 2006, 05:03 PM
