  #21
Old July 12th, 2006, 11:16 PM
Good job fixing it. Yes, that complete assembly is a lifesaver.
Old December 28th, 2006, 09:15 AM
Enclave is on a distinguished road
Default Instructions for changing inner/outer tub assembly?
Originally Posted by Jake View Post
Actually it would be better and cheaper to buy the complete inner and outer tub assembly, would be more expensive than just the bearing, but probably save you hours of labor time, and pounding to get that bearing out, which is no easy task to remove on some units.
I intend to buy the complete inner and outer tub assembly in order to install new bearings in my Kenmorelace 417.41042000. Are there any instructions posted showing the best order of disassembly and small tricks to make it easier? I am sure those that have changed these out many times have learned a few things along the way.
Thank you.
Old June 14th, 2007, 06:29 AM
Fridgidaire Hater is on a distinguished road
After researching the fridgidaire/sears/electrohome, I am finding that these things are absolute crap. The spiders are acting as sacrificial anodes and are corroding/rusting at a ridiculous rate. I have a water softener at my house, so we use even less soap than normal, always liquid, always the recommended brands. I got the same song and dance, however, I found a lucky break.
When I phoned Sears Canada for parts , I was pricing out the individual parts, drum, seals, etc, and was disgusted with the total price. I asked when the rear assembly would be....152.00. I asked if they had a complete tub assembly, the girl said yes , and the price was.......152.00
I asked her to hold it for me, drove to the parts depot (Winnipeg) and picked it up. Lo and behold, the whole tub assembly for $152.00. I followed the blog on assembly (found elsewhere in these forums, including full colour photos...thanks for the details, it worked perfectly. I should get another 3 years out of it.
http://www.applianceblog.com/washers/RearBearingV6.pdf
Sears and Fridgidaire will never get 1 dime of my business again. They did not stand behind their products, and if anything, this is a structural defect that should have been covered by a recall. I am going to post these blogs to consumer reports and consumer and corporate affiairs. My previous maytag washer lasted 22 years, and it was still working fine when I sold it. This piece of crap didn't last 3 years. What a joke.
Last edited by Fridgidaire Hater; June 14th, 2007 at 06:32 AM.. Reason: add link to photos
Old July 29th, 2007, 04:40 PM
tjromeo is on a distinguished road
Question Kenmore washer bearing noise but...
Our Kenmore washer, model 41729042991, also sounded like a jet taking off. As per other posted messages I concluded that it was the bearing and therefore replaced the rear outer tub assembley and shocks as per Jake's instructions. Everything seemed to go well. As per another suggestion I did run it through 2 wash cycles (without clothes) out in the garage to make sure there were no leaks. All seemed fine, it sounded like a new washer. So I brought it back in the house, stacked the dyer on top put a load of wash in. As it started the wash cycle there were two loud clunks as it began to agitate and from then on it will not agitate or spin. I took all the clothes out and tried it again empty but it will only fill and drain as normal without any agitation or spins. Any suggestions ???? Thanks
Tj
Old July 29th, 2007, 10:33 PM
Two loud clucks? Check the belt to make sure it didn't come off. Try to turn the tub with your hand both ways without clothes.
Old July 30th, 2007, 03:21 AM
Default Kenmore washer
As the machine started to agitate in one direction it clunked, and then as it reversed direction it clunked again and then it stopped. I first thought it was out of balance due to the clothes. The belt appears to be ok and the motor is not free spinning during the agitation or spin cycles. The drum turns freely in both direction. Is there somesort of electonic lock out if it was originally out balance due to the clothes or a reset to prevent it from spinning or agitating? I did disconnect the power to it for 20 minutes or so and turned it back on but that did not do any good. What do you think?
Old July 30th, 2007, 08:54 AM
No, theres no lock-out for unbalanced loads.
I don't know what the problem could be, it worked good before you moved it, so I assume something broke lose or came out of place during the move.
Unfortunately, you may have to take it apart again to see what might have happened.
Old July 30th, 2007, 06:05 PM
Wink Kenmore Washer
You were correct something did come loose. The connector to the motor was loose. I reconnected it & made sure this time it was well seated. Put things back together and presto.... it works and is quiet as well !!! I have to admit I had my doubts but things worked out well. Thanks for all your assistance.
tj
Old July 30th, 2007, 10:40 PM
Good job finding that loose motor connector. Yes, its amazing how quiet it becomes when you change out that rear tub assembly.
Old June 30th, 2008, 08:56 AM
baumanb is on a distinguished road
Default Kenmore 417.42052100 washer
Hi there:
It sounds like I have a bearing(s) going out on this unit. I phoned a local applicance sales/repair place. They listened to the noise over the phone and suggested it would be cheaper to buy a new one than fix this one. They suggested that this particular model was not "well made" and that I would do a lot better buying a Maytag Epic Z for $675 after rebates...
Can you offer an opinion on their opinion?
thx
BB
Kenmoe 417 Bearing Noise Question qman Sears Kenmore 12 November 21st, 2009 10:11 PM
Checking bearing on Sears 417.xxxx ChrisDavis Sears Kenmore 1 February 20th, 2006 12:01 AM
Sears HE3 dryer thumping noise joat Dryers 6 October 30th, 2005 12:05 PM
Kenmore Laundry Center how to remove drum support bearing anfld Sears Kenmore 1 October 12th, 2005 05:48 AM
Kenmore dryer drum rubbing noise mattj Sears Kenmore 9 September 30th, 2005 11:19 PM
