#31
Yes, thats true. Unless you have the time on your hands to take your washer apart and fix it, I'd recommend the Maytag Epic Z as well. Jake
#32
I am in the middle of replacing the washer tub including bearing and seal. I have the bearings in but am unclear on the install of the seal. It doesn't seem to have any place to sit/attach. I am wondering if I put the bearing in to far. I assume the seal should 'attach' around the lip of the bearing but I don't have an 1/8 of an inch to hold the seal. Any help would be appreciated.
Thanks |
#33
If I remember correctly, the inner bearing seat in far enough for you to install the seal... I actually had to gently use a rubber mallet to install the seal.
Check from the hole in the outer bearing if your inner bearing is seated correctly. Between the two bearing there should only be a flat metallic cylinder, if you have a depression between them then your bearing is not seated correctly. I've used copper grease around the contact point of the shaft and the seal to reduce wear and improve sealing. I don't know is that was the right call though. MageMinds |
| Kenmoe 417 Bearing Noise Question | qman | Sears Kenmore | 12 | November 21st, 2009 10:11 PM |
| Checking bearing on Sears 417.xxxx | ChrisDavis | Sears Kenmore | 1 | February 20th, 2006 12:01 AM |
| Sears HE3 dryer thumping noise | joat | Dryers | 6 | October 30th, 2005 12:05 PM |
| Kenmore Laundry Center how to remove drum support bearing | anfld | Sears Kenmore | 1 | October 12th, 2005 05:48 AM |
| Kenmore dryer drum rubbing noise | mattj | Sears Kenmore | 9 | September 30th, 2005 11:19 PM |
