Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: 417 Sears drum bearing noise
    Ian
    Ian is offline Member
    Sep 2005
    Philadelphia, PA
    Question 417 Sears drum bearing noise
    My Sears 417.29042992 (made 10.99) sounds like a aircraft engine when spinning. I have taken off the back and examined the pulley and motor. The only place the noise seems to be able to come from is the rear bearing on the outer tub assembly. I also feel a bit of uneven rumbling from the drum when I spin it by hand. I know the entire rear outer tub assembly is available, but is it possible to replace just the rear bearing? If so what part # is it? If I do in fact have to replace the whole rear outer tub assembly, what procedure should I follow? I also will be replacing the two tub shocks, but those seem straightforward. Thanks in advance for your help.
    -Ian Hemphill
    Here is the link to the guide about changing just that bearing:
    [FIXED] Drum Gasket and Rear Shell Bearings
    Actually it would be better and cheaper to buy the complete inner and outer tub assembly, would be more expensive than just the bearing, but probably save you hours of labor time, and pounding to get that bearing out, which is no easy task to remove on some units.
    Here is the complete inner and outer tub assembly you can buy:
    Inner & outer tub assembly
    KarMo is offline Member
    Jan 2006
    Belmont, MA
    Default Water leaking under my Kenmore 417
    I actually wanted to start a new post, but am new & don't see how to do it.
    I LOVE my little Kenmore 417 front loader! Yes, it sounds like an airplane engine (for a minute or two); that's why it gets my clothes SO dry. It's great.
    I have model #417.42042100, bought Feb 2002, nearly 4 years ago.
    Here's my problem: for a long time (probably 3 years), I've had some water leaking from under the front of the washer, during the final FAST spin ONLY. I checked the hose connections; no leaking there. At first it was just a small amount (maybe 1/2 cup) and I placed a towel under the front of the washer to soak up the water. The floor doesn't get wet further back--it just seems to be happening at the front.
    But these days, it's starting to leak more. It still happens only at the end of the final spin cycle, but now it's pretty much soaking a bath towel. I'm afraid it's going to start gushing one of these days.
    Just now I went to RepairClinic.com and looked at the parts for my washer. I wonder whether it could be the boot seal, or the pump. I wouldn't be able to repair this myself, but just want to know if it sounds like a major problem & whether it's worth repairing. I love this machine, and hate to put myself in the hands of the folks from Sears (I haven't even called them about this yet).
    I would appreciate any insights you might have.
    You have a bad middle tub seal, its very costly to have this replaced, and the entire machine has to come apart to get to this seal.
    A repair company is likely going to charge you close to $300 to do this job.
    May be a better idea to use that money for a new washer, as this model has had multiple other problems, like the bearings.
    Jan 2006
    Belmont, MA
    Default Water under my Kenmore 417
    Wow, this is bad. You're right, it's not worth repairing.
    So my next problem is that I'm using this as a stacking washer/dryer with the Kenmore gas dryer. Together they just fit into the space for it.
    Is this washer still made? Any chance that I could buy the same one?
    Thanks for your help. You're very knowledgeable.
    Yes, i believe, just take the model# down to Sears and they should be able to match it with the same or similar model.
    jshorey is offline Member
    Mar 2006
    Durham
    Default Kenmore leaking problem
    I had the same problem... it was leaking from between the 2 parts of the shell. Tightening the bolts didn't fix it. I bought a new seal and took the tub appart (about 30 bolts) and stuck the new seal in. I also replaced the shocks and the belt while I was at it. Took about 3 hours... removing the shocks was difficult. I wasn't sure about putting back the door seal. I ran it in the garage 3 times and no water came out so I guess it was a success. The part was cheap at least.
    aniwayne is offline Member
    Sep 2005
    california
    hmmm... I think I am experiencing the same problem. kenmore 417. Just noticed it today. There are fast drips coming from underneath the washer in the front left of the machine. I noticed that the screw down there (left side of lowest panel) is rusting/rusted. The screw on the right side of the lowest panel is fine. So, I scheduled a technician to come out on Monday... but it's gonna cost 70$ just for the "trip fee". Wonder if I should just forget the tech and start searching for a new washer. Too bad.. it's not even a full 4 years old yet. Bought it in Oct. of 2002. Love the washer though.
    Maybe we can take the bottom panel off tonight and inspect it ourselves. Do you think we have a pretty commen problem here?
    By the way, there is a lifetime guarantee on the steel wash basket-could we be lucky enough to have this be what has failed?
    ~Aniwayne
    Mad Mac is offline Appliance Tech
    Jan 2005
    Moorpark (via Motherwell, Scotland), California, USA
    This seems to be more and more of an issue on these. I'd open the bottom panel and have a look.
    Sep 2005
    california
    okay, took your advice and removed the bottom panel. Discovered water was leaking from the tub seal? Similar replacements of the tub seal are not costly, however very time consuming and tedious assuming you are good with your hands. If you are not, sol!
    In a dilemna.. order the tub seal for $35 and try to replace myself? (and maybe not be succesful) or just purchase a new dishwasher (top loading only this time!)
    One last hail mary maybe to contact the manufacturer in hopes of the "Silent" recall.
  1. Kenmoe 417 Bearing Noise Question
    By qman in forum Sears Kenmore
    Last Post: November 21st, 2009, 11:11 PM
  2. Checking bearing on Sears 417.xxxx
    By ChrisDavis in forum Sears Kenmore
    Last Post: February 20th, 2006, 01:01 AM
  3. Sears HE3 dryer thumping noise
    By joat in forum Dryers
    Last Post: October 30th, 2005, 01:05 PM
  4. Replies: 1
    Last Post: October 12th, 2005, 06:48 AM
  5. Kenmore dryer drum rubbing noise
    By mattj in forum Sears Kenmore
    Last Post: October 1st, 2005, 12:19 AM
