October 26th, 2011, 12:46 PM
Dryer door switch wiring question
I've got a 11-year old Kenmore dryer model 417.69042990. I just bought a new door switch for it but idiotically didn't make proper note of where the wires go. Here's what the switch looks like:
Here is a picture of the switch terminals (let's call them 1, 2, and 3, left-to-right, top-to-bottom):
(note: terminal 2 is narrower than the other two terminals)
Here is a picture of the wires. You can't tell the wire colors from the picture but the left wire is solid brown, the middle wire is solid blue, and the right wire is solid grey:
Thanks for your help.
October 26th, 2011, 07:46 PM
Been there, done that...lol Put the small terminal wire on then take one of the other wires and touch it to one of the other terminals until the light comes on. When the light comes on put that wire on that terminal and the other one on the one that's left.
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
October 26th, 2011, 10:01 PM
Originally Posted by
rickgburton
"Put the small terminal wire on" ..
Which is the correct wire for the small terminal? Brown, blue, or grey? Thx
October 26th, 2011, 10:59 PM
Which wire has the smaller terminal end on it? It's most likely the one with the plastic around the end. Even if you make a mistake you won't hurt anything. It looks like the wire on the left goes in the middle. If that style Kenmore (Frigidaire) dryer has a lower front panel that comes off, there will be a wiring diagram behind it.
By waldreps in forum Dryers
Last Post: December 8th, 2008, 12:39 PM
By JACKSPRAT in forum GE/Hotpoint
Last Post: December 7th, 2007, 04:48 PM
By ronypi in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 5th, 2007, 08:02 PM
By jnunnelee in forum Sears Kenmore
Last Post: December 19th, 2006, 08:52 PM
By dljfine in forum Sears Kenmore
Last Post: June 27th, 2006, 06:10 PM
